Thread: Radiator pep cock
Results 1 to 6 of 6
  1. #1 Radiator pep cock
    virginia
    2002 grand prix radiator pep cock. Mine turned 1/4 rev and stopped and no coolant drained. Should it turn further or is the drain plugged?
  2. #2 Re: Radiator pep cock
    Charles City, IA
    It is plugged just pull the lower hose.
    SMGPFC Two Nipple General
  3. #3 Re: Radiator pep cock
    Donating Users Liquifire's Avatar
    Wausau, WI
    it is plugged it does not turn more than a quarter turn. Get a coat hanger if you can in there and see if you can loosen it up.
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  4. #4 Re: Radiator pep cock
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    I don't know if this may apply but when I did this a few week ago with my 98 it turns a 1/4 turn and then pulls out.
    Most people pull the lower hose, seems like that's an easier way to do it.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  5. #5 Re: Radiator pep cock
    Ohio
    u have to pull it out once u turn it.
    00 GTP demodded and forsale
  6. #6 Re: Radiator pep cock
    GT Level Member skidoojames151's Avatar
    seattle
    lol its petcock not pep cock...
  1. Radiator Overflow Cap
    By kingbrentdwyer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2009, 06:22 AM
  2. Fan rubbing on the radiator
    By Infinity9999 in forum General Tech Discussion
    Last Post: 12-23-2008, 11:43 PM
  3. replacing the OEM radiator
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2008, 06:09 PM
