Thread: ABS System Reset
Results 1 to 6 of 6
  1. #1 ABS System Reset
    Omaha, NE
    Anyone know how to reset the ABS system on the 98 Grand Prix? We have tried to disconnect the battery completly for 15 mins+, as well as unplug the top half of the ecu, however noluck. we have also replaced both front wheel bearings, which should have corrected the problem. I dont believe the ecu is completly resetting as the radio presets are not going away. Is there anything simple im missing here?
  2. #2 Re: ABS System Reset
    Wausau, WI
    you mean a reset just to get the code off of your dash or what?
  3. #3 Re: ABS System Reset
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    i "thought" the abs system reset itself everytime you shut the car off, then restarts once you start the car and move it a couple feet..... it does that little test....
    regardless, what made you think it was specifically your wheel bearings?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: ABS System Reset
    Wausau, WI
    it has probably reset now, as he is no longer posting on this thread......oh well
  5. #5 Re: ABS System Reset
    Omaha, NE
    I talked to a Pontiac Mechanic, and it is correct that the ABS system reset upon so many key cycles. The ABS light is still on so we are guessing the harness wires are broke or something on one of the two front wheel bearings, as they have both been replaced and the light still is on. We had a mechanic replace both of the front wheeel bearings as they were bad, and desperatly needed replaced.
  6. #6 Re: ABS System Reset
    Nov 2008
    Fremont Nebraska
    the wire harness is completely possible. thats what happened to me. it was on the passenger side
  1. How to reset tire pressure monitoring system?
    By gpcruzin in forum Tires & Wheels
    Last Post: 12-07-2011, 12:06 PM
  2. where is fuel pump reset on 2001 GT
    By keven in forum General Tech Discussion
    Last Post: 07-12-2009, 05:46 PM
  3. oil monitor in DIC wil not reset
    By jojosgrampa in forum Introductions/Noob Questions
    Last Post: 05-24-2009, 01:52 PM
  4. reset abs
    By 99gpse in forum Off Topic Discussion
    Last Post: 04-11-2009, 09:02 PM
  5. how do i reset the theftlock???
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-29-2008, 03:08 PM
