Thread: bugging/puttering help needed
Results 1 to 5 of 5
  1. #1 bugging/puttering help needed
    Chicago
    I recently did a tune up on my car and ever since I changed my stock wire, ngk spark plugs, and 180* T-stat with Taylor 8mm wires, autolite 106 plugs and 160* T-stat I been bugging at launch and puttering under WOT. I even went back to my 3.4 pulley and still the same. Any1 kno what can be causing this?
  2. #2 Re: bugging/puttering help needed
    Chicago
    no1 has any ideas what can be causing this?
  3. #3 Re: bugging/puttering help needed
    GTP Level Member Scimmia's Avatar
    QCA, IA
    crack a spark plug while installing? break a plug wire? I've never heard of anyone using autolite 106s, maybe wrong plugs?
    BTW, 160* is pretty cold for the tstat, extra wear on the engine for very little gain.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: bugging/puttering help needed
    Chicago
    Quote Originally Posted by Scimmia View Post
    Typed wrong plugs. their 104s.
    but the wires look good. and I didnt tightin the plugs tight
  5. #5 Re: bugging/puttering help needed
    Chicago
    Ok so I switched backed to stock wires and NGK TR6 plugs and still same prob. Could I have a bad/clogged injector? or maf sencer?
  1. top swap help needed!!!
    By gtjohn98 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2009, 02:07 AM
  2. Opinion Needed on GTO
    By Vespers47 in forum Off Topic Discussion
    Last Post: 02-27-2009, 04:27 PM
  3. S/C is bugging out
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2009, 01:38 AM
