Thread: radiator hose
Results 1 to 10 of 10
  1. #1 radiator hose
    Donating Users
    Plainfield, IL
    hey guys i noticed the radiator hose under the coil bracket pinches shut when i give the motor throttle....is the hose just old an collapsed?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: radiator hose
    Wausau, WI
    do you have any air in the lines? It may need to be bled if that is the case...when does it do it? after driving awhile.........just coming up to temp? Please explain the scenario.....
  3. #3 Re: radiator hose
    Donating Users
    Plainfield, IL
    just when i give the motor throttle it collapses....
  4. #4 Re: radiator hose
    Wausau, WI
    I had seen my other one collapse........the one going after the thermostat into the rad. but this was right after I had done the coolant change over.....I bled it and refilled it completely and it has been fine ever since.......fwiw
  5. #5 Re: radiator hose
    how flexy is the hose? how old is it? might need a new one.
  6. #6 Re: radiator hose
    Donating Users
    Plainfield, IL
    100k old prob thats what my car has....i bled the system for awhile when i threw in the 180stat so i dont see there being any air in there but i guess its possible....im willing to bet its old...and needs replacing...
  7. #7 Re: radiator hose
    when they start collapsing they are usually just old and need to be replaced. have fun getting coolant everywhere.
  8. #8 Re: radiator hose
    Donating Users
    Plainfield, IL
    ehh i been wanting to get rid of the dexcool for awhile now ....this is a good excuse and do i need to go to the dealer for this part?
  9. #9 Re: radiator hose
    you can probably get it at autozone or another local parts store.
  10. #10 Re: radiator hose
    Donating Users
    Plainfield, IL
    cool then thanks!
  1. Which is the hose the goes to heater core?
    By DesertFox in forum General Tech Discussion
    Last Post: 05-16-2009, 06:08 PM
  2. vaccum hose?
    By kingd44 in forum General Tech Discussion
    Last Post: 10-13-2008, 05:35 PM
  3. Vacuum hose
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2008, 07:01 AM
  4. IC hose fittings?
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2008, 10:32 PM
  5. Radiator Hose Diameter
    By 03GPScottyd in forum General Tech Discussion
    Last Post: 05-20-2008, 03:01 PM
