Thread: What ther GM cars with same/ functional fuel sending/ pump units?
Results 1 to 4 of 4
  1. #1 What ther GM cars with same/ functional fuel sending/ pump units?
    Feb 2009
    NE
    We have 2 GRand Prix's. One had the common fuel gauge stuck on full 98% of the time issue and I put a new sending unit in it to fix. Now the other GP fuel gauge is acting up. It should not cost $280 to fix a fuel gauge when the issue is the simple sweep tabs that rub on the variable resistor for the float swing. Anyhow, I go to the local U- pull it and keep an eye out for Grand Prixs. I have missed 4-5 as the first dam thing pulled from a GP is the fuel sending unit/ pump. Anyhow, I walk by 50 Luminas, Bonnevilles, etc. but find they do not have the nice easy truck fllor hatch access. Anyone know of another GM car with truck access that uses the same sending unit that may just need the float are swapped or something?
  2. #2 Re: What ther GM cars with same/ functional fuel sending/ pump units?
    GTP Level Member SuperSport's Avatar
    Michigan
    00-05 Impala, 00-05 Monte Carlo, Olds Intrigue, Regal. To be safe, pull from a 3.8 non-supercharged equipped car.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: What ther GM cars with same/ functional fuel sending/ pump units?
    Feb 2009
    NE
    Any tips on cars that have truck access panels instead of having to drop the tank?
  4. #4 Re: What ther GM cars with same/ functional fuel sending/ pump units?
    Banned - Busted For Scamming
    Feb 2009
    Buick centurys have the access panel/ fuel sender. I know the other ones probably do too.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. fuel sending unit
    By stanggreg90 in forum General Tech Discussion
    Last Post: 08-01-2009, 06:23 PM
  3. are fuel sender units compatible with other brand gauges?
    By fst in forum General Tech Discussion
    Last Post: 10-03-2008, 04:42 PM
