Thread: bbv open air
Results 1 to 16 of 16
  1. #1 bbv open air
    Donating Users
    Plainfield, IL
    hey guys i took the lower vac hose off the bbv and plugged the vac fitting on the sensor on the bbv....now thats its blocked couldnt i just take the sensor and hard vac line out and switch the t fitting on the FPR to an L fitting? then when i tune delete the code? no ill effects will be seen from his right?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: bbv open air
    Charles City, IA
    Why are you getting rid of the BBV?????
    SMGPFC Two Nipple General
  3. #3 Re: bbv open air
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Yep, you can do it that way just fine.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: bbv open air
    Donating Users
    Plainfield, IL
    can this mod result in more knock or no? im knocking so much right now that i dont know it if it had ill results as far as KR....oh well tune time for me....
  5. #5 Re: bbv open air
    Charles City, IA
    That is all this mod will do. Add more part throttle knock and kill your mileage. No point at all to do it.
  6. #6 Re: bbv open air
    QCA, IA
    01GTP, you need to understand what he's doing before making comments like that. All he did was take the solenoid out, so the BBV is functioning like normal.
    No, this will not cause knock. If the actuator isn't functioning, it could cause some part throttle knock, but it would do that with or without the solenoid.
  7. #7 Re: bbv open air
    Charles City, IA
    Quote Originally Posted by Scimmia View Post
    Ok, I thought he was going to take the whole thing off. Now im curious as to why take the solenoid out?
  8. #8 Re: bbv open air
    Banned - Busted For Scamming
    Feb 2009
    Because it goes bad. And when it goes bad, it kills your boost. And it could be intermittent also. Plus mad burnouts lol.
  9. #9 Re: bbv open air
    Moore, Oklahoma
    Just curious, have you had first hand experiance? If so, exactly what did yours do? I think mine is causing some boost issues curently. Just curious what you've experianced....
    Shawn W. Larsen
  10. #10 Re: bbv open air
    the only thing this causes is that the PCM cant pull boost when it normally would. you have to tune around that by working with torque management and stuff while youre shifting and what not.
  11. #11 Re: bbv open air
    canada
    i have plugged my solenoid also, but what you guys are saying when i get my tuner i will have to tune different because of it?
    1998 GTP 2Door
  12. #12 Re: bbv open air
    Quote Originally Posted by Standby View Post
    you have to be weary that when torque management engages that it no longer has the ability to bleed boost. full boost + less fuel = bye bye motor. you have to adjust things accordingly so it doesnt pull fuel when you are still boosting hard.
  13. #13 Re: bbv open air
    Feb 2009
    No, they say you can delete the code if you want.
  14. #14 Re: bbv open air
    Feb 2009
    What do you mean, less fuel? Map and Maf along with oxygen sensor readings make sure that doesnt happen.
  15. #15 Re: bbv open air
    QCA, IA
    There are situations where the computer will purposely pull fuel, in diff abuse mode for instance. If that happens under high boost, it could be dangerous. IMO, it's dangerous in a modded car anyway, this doesn't make it that much more.
    Edit, thinking about it more, I'm thinking it disables injectors, so it's really not extremely dangerous, but certainly not ideal.
  16. #16 Re: bbv open air
    Feb 2009
    Some times i would get full boost, other times i wouldnt. Immediately i knew it was the problem, it was sticking open allowing boost to enter the bottom side of the diaphragm. Once i disabled it, havent had a problem to this day with it building boost.
  1. EGR is stuck in open
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 10:32 AM
  2. sunroof wont open
    By whitegtp in forum General Tech Discussion
    Last Post: 03-24-2009, 08:08 PM
  3. ughhh, trunk wont open!
    By black98gt in forum General Tech Discussion
    Last Post: 03-12-2009, 08:23 PM
  4. How do I fix my door swinging open?
    By onehitznj in forum General Tech Discussion
    Last Post: 12-07-2008, 10:37 PM
  5. open air filter in engine bay
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2008, 04:21 PM
