hi everyone. i was just wondering if any body had photos of the under side of their GP's?
mine is rusty..........that is wisconsin salt for you........which parts do you need pics of, or what for?
well, i was wanting to see the exhuast system and was wanting to plan out a new exhuast. also, and this might sound dumb, but i'm wanting to remove my cat and not too sure which is the cat and which is the res.
the cat is more near the motor before the u bend and before the res........
check this link out.......it has part of the exhaust in a pic.....http://www.grandprixforums.net/f17/zzp-dp-19023.html
so, in order to remove the cat? do i have to replace any sensors or anything? i think i also read somewhere to do something about the ubend? thanks alot liqiufire.
you want to get rid of the u bend(that is where the rear o2 sensor resides in a stock setup) that is the most restrictive part of the exhaust. If you are unbolting the downpipe with stock you would have to remove the 02 sensor. If you are cutting it out you wouldnt have to but I dont know why you wouldnt have the u bend deleted if you are doing any exhaust work. Have you looked into getting a whole new downpipe? You can get them in upgraded size, with or without cat including the u bend deleted for about two hundred(if with the cat) or cheaper without from zzperformance.com..... let me know if you have any more questions.
