Thread: Key stuck in ignition-
Results 1 to 5 of 5
  1. #1 Key stuck in ignition-
    Feb 2008
    Light on gear indicator stays on when key stuck. Doesnt happen all the time. Key goes back almost all the way- not enough to get key out.
  2. #2 Re: Key stuck in ignition-
    Saraland Alabama
    could be shift interlock (or whatever it's called in the console) it keeps you from being able to lock the wheel while in gear
  3. #3 Re: Key stuck in ignition-
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Stick pen in hole under little plastic cap on bottom of steering colum cover right under the ignition.
    Key comes out every time.
    You can zip tie that switch and it will never get stuck again.
  4. #4 Re: Key stuck in ignition-
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by VinnieGTP View Post
    seems like an interesting approach, but isnt it kinda a safety feature?
  5. #5 Re: Key stuck in ignition-
    Saraland Alabama
    and in mine it goes off far enough to shut off the light when the column one sticks (why I went to the transmission one) the column one stick frequently also though
  1. Key stuck and Dead Car
    By joe_cool in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-20-2010, 04:13 PM
  2. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
