Thread: Plug Wires?????
Results 1 to 19 of 19
  1. #1 Plug Wires?????
    SE Level Member 2k6GT's Avatar
    Troy
    What kind of plug wires should i go with?????????? i heard zzp arent too shabby but i want to hear what you guys think.
  2. #2 Re: Plug Wires?????
    Charles City, IA
    http://www.topdeadcenterracing.com/P....aspx?CatId=24
    Cheaper and better. I have the zzp ones tho and no complaints.
    SMGPFC Two Nipple General
  3. #3 Re: Plug Wires?????
    TDCRacing
    Guest
    Our wires have surpass the ZZP wires in every way. We use high quality silicone boots with dual crimp terminals. Our wires also offer unbeatable RFI suppression.
    That paired with MSD Pro Race Boots have made these wires the best you can get.
  4. #4 Re: Plug Wires?????
    Portland Oregon
    Quote Originally Posted by TDCRacing View Post
    I have to respectfully disagree here. If your wires are essentially the same as the 10.4mm wires sold at 3800performance using taylor spiro pro wire and MSD boots then the set that I had started to cause ticking interference in the radio after about 15k miles. I don't doubt the wire is an excellent performance alternative to stock, just providing my feedback. No pun intended.
  5. #5 Re: Plug Wires?????
    TDCRacing
    Guest
    Quote Originally Posted by OH4CompG View Post
    Really? I have heard of othe issues causing a ticking sound in the radio (Such as RCA cables for an amp ect)
    Did you remove the wires and the ticking sound went away? If so and it has not been to long after the milage you stated then I would definetly call 3800Pro up and see about them sending you another set. This a first of anything happening like this to my knowledge.
    I'm not sure how these would cause something like this to happen and the stock wires would not.
    Intresting none the less.
  6. #6 Re: Plug Wires?????
    wires are wires so long as you replace them on the recommended schedule of you motor...
    ...sorry parker...
  7. #7 Re: Plug Wires?????
    TDCRacing
    Guest
    ...sorry parker...
    I agree to a certian point. Plug wires are not going to give you any kind of horsepower gain. But they are not ment to. They are ment to be an improvement over stock and that's what they are.
    There are dramatic differences between different types of wire. Ever try hooking up that 1500 watt amp with wire the size of a tooth pick? Did not work to well now did it?
    If your looking to upgrade your plug wires or you need new ones for some reason or another why not get the best?
    But if someone was asking me what to do to their car to get more horsepower out of it plug wires would not be on the top of the list by any means.
  8. #8 Re: Plug Wires?????
    Banned - Busted For Scamming
    Feb 2009
    Yup. Ill run fine on my stockers so long as there in good shape. Take your money and buy something useful.
  9. #9 Re: Plug Wires?????
    Charles City, IA
    Theses come off easier too.
  10. #10 Re: Plug Wires?????
    GTP Level Member Scimmia's Avatar
    QCA, IA
    It certainly can happen with stock wires, too. I have RFI from my current Delco wires. Taylor 409 are good wires, but "unbeatable" is a very strong statement, especially with a Magnecor group buy still going on.
    2001 Buick Regal LS - Almost Stock
  11. #11 Re: Plug Wires?????
    Portland Oregon
    Yep, went back to stock wires and the tick went away. Those wires are long gone with the car when it was wrecked
  12. #12 Re: Plug Wires?????
    Aftermarket stereo?
    I've have a aftermarket stereo and aftermarket plug wires and I've never had that issue. And I don't have it set on granny volume either so I'd know if it was crackling or not.
  13. #13 Re: Plug Wires?????
    Charles City, IA
    ^ x2
  14. #14 Re: Plug Wires?????
    Moore, Oklahoma
    I just use stock replacement lifetime wires from OReillys... Borg/Warner brand and replace them every other year or so free of charge. Best $40 investment i've made. I like having fresh wires time to time.
    I had MSD 8.5 mm wires back in 2002, they didn't last 9 months without completely crapping out and miss firing. Had them properly protected and separted too. Biggest waste of $80 i've ever spent...
    Shawn W. Larsen
  15. #15 Re: Plug Wires?????
    Feb 2009
    ^^^ Was about to say that. I love lifetime replacement.
  16. #16 Re: Plug Wires?????
    Portland Oregon
    Had the stock stereo still. No other good explanation for the ticking other than the wires
  17. #17 Re: Plug Wires?????
    Feb 2009
    The reason why they are more powerful wires is they have less resistance. Less resistance equals more RFI. It only makes sense.
  18. #18 Re: Plug Wires?????
    Barksdale AFB, LA
    I have PRJ's wires (which TDC's are either made by PRJ or copies made with the same materials). I also have an aftermarket radio. No ticking or interference, nor any reported by any other PRJ users on NAIOA.
    2009 Subaru Impreza WRX STI
  19. #19 Re: Plug Wires?????
    QCA, IA
    The thing about the 409s is that they use a carbon conductor sheath over their spiral wound core. Carbon conductors work fine for conduction and work well for suppression, but they wear out. Once they do, you're going to end up with the spiral wound conductor that's not suppressed as well. For those asking about aftermarket stereos, that's immaterial. When the wires emit RFI and EMI, they interfere with all of the electronics in the car. Just because you can't hear it doesn't mean it's not causing problems with all of the other electronic systems controlling the engine. Suppression is one of the more properties of spark plug wires, with measured DC resistance way down toward the bottom of the list.
  1. Spark plug wires!
    By gonzo915gp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2009, 11:14 PM
  2. Plugs and Plug Wires
    By Chernobyl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2009, 03:48 PM
  3. Plug wires
    By 04muscle in forum General Tech Discussion
    Last Post: 03-09-2009, 01:02 AM
  4. Plug Wires
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 11:56 PM
  5. Plug wires
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2008, 03:12 PM
