Thread: Few Questions 98GTP
Results 1 to 14 of 14
  1. #1 Few Questions 98GTP
    GXP Level Member
    Theworld
    I just picked up a 98 GTP last week.
    It's got problems, nothing major really.
    First the HUD keeps going in and out (banging on the dash doesn't do anything) It works when it wants to.
    -Anyone know of reasons or ways to repair?
    Second, my info station went out, I was told it's just a bulb, is this true? (It went out from banging on the dash lol!)
    Third, has anyone know the oil pan gasket to go bad, or leak? I think that's where my oil leak is (multiple drops a day)
    Thanks!
  2. #2 Re: Few Questions 98GTP
    Wausau, WI
    info station? you mean your DIC? if so this has I think three bulbs in it that can be replaced. you just have to take apart the dash to access it............not sure on the HUD unit, you may just have to replace it. Ed Morad should have some of these for sale or your local junk yard. If you do replace it, just make sure it is bright before you install it. They fade over time.... My oil pan might leak a tiny bit, but it is bent from previous owner........so not a good barometer.
  3. #3 Re: Few Questions 98GTP
    GXP Level Member
    Theworld
    Also, one thing I also forgot to add:
    The rear passenger side window does not stay up, the motor spins but the window is able to move freely.
    Not to sure about fixing it, never done that before.
  4. #4 Re: Few Questions 98GTP
    Becca Boo MizzBecca's Avatar
    Michigan
    Quote Originally Posted by KawaFord View Post
    ROFL @ the 'banging on the dash doesnt do anything' you probably pissed your car off for hitting it, so it's just not gonna work ;p
    And as for the oil leak, my whip leaks too right near the seal. I know alot of GP's have oil leak problems. Mine has left spots all over my work parking lot.
    I drive a POS
  5. #5 Re: Few Questions 98GTP
    On the HUD, the issue you are most likely experiencing is the photocell has a cold solder joint. This is a very common issue with GP HUD's.
    Pop off the dash trim covering the HUD and remove the hud unit from the dash. Open it up and there is a silver round component on the circuit board over in one corner. Reflow the solder and plug it in for a test. tap and wiggle to ensure the HUD is 100% before putting it all back together.
  6. #6 Re: Few Questions 98GTP
    GXP Level Member
    Theworld
    Thanks, I'll give it a try, I'll keep you posted.
    Not this weekend, but next weekend I'm going to pull the motor and slap on a new oil pan and gasket.
  7. #7 Re: Few Questions 98GTP
    Charles City, IA
    ^ just fixed mine last night. Do a search on google and you can find a how to with pics.
    SMGPFC Two Nipple General
  8. #8 Re: Few Questions 98GTP
    GXP Level Member
    Theworld
    Just fixed what?
    Does anyone know where to get the bulb replacements for the info station?
  9. #9 Re: Few Questions 98GTP
    GXP Level Member
    Theworld
    ttt
  10. #10 Re: Few Questions 98GTP
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    This thread has directions on how to replace the DIC bulbs:
    http://www.grandprixforums.net/f81/d...-up-17300.html
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  11. #11 Re: Few Questions 98GTP
    Charles City, IA
    Fixing the two solder joints for the photo cell.
  12. #12 Re: Few Questions 98GTP
    Wausau, WI
    kawa.........you good to go now? I would think you can get lights from the stealership if you can't anywhere else.........
  13. #13 Re: Few Questions 98GTP
    GXP Level Member
    Theworld
    Quote Originally Posted by Liquifire View Post
    What I did was borrowed the light from the (Traction Warning Light)
    So it's pretty good for now.
    Until that one blows, I'll probably forget about getting new lights..
    I want to worry about the bigger problems first really.
  14. #14 Re: Few Questions 98GTP
    Wausau, WI
    fair enough.........first things first........
  1. PCV questions
    By Blackbeauty01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2011, 11:16 PM
  2. New guy with old questions I'm sure
    By bpm4x4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-23-2009, 06:36 PM
  3. Few Questions
    By shape275 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2009, 09:10 PM
  4. I need help with my 98gtp
    By TheGreatSamG in forum General Tech Discussion
    Last Post: 03-10-2009, 12:17 PM
  5. 98gtp Tran Swap! (pics)
    By FoSHO99 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-01-2008, 07:04 PM
