Thread: Need advice now on buying gtp
Results 1 to 20 of 21
  1. #1 Need advice now on buying gtp
    GT Level Member Black18Ice's Avatar
    Iowa
    Maybe this should be in the lounge I didn't know. Anyways I am looking at a 1998 gtp coupe. It is loaded with 195,000 miles. It needs a fuel pump, brakes and rotors(look bad and pulsating), supercharger coupling(sounds like rocks), alternator?(bad whining from alternator?), and new front pass. tire and shock mount?(shock moves around on top of tower. Maybe bad mount idk. Guessing it is the reason for the bald tire.
    He is asking 1700. Car is pretty much rust free and the other 3 tires are great. I drove the car some. Does this seem like too much work and money to put into it? Thanks
  2. #2 Re: Need advice now on buying gtp
    Charles City, IA
    Well it depends. Can you do the work your self or will you have to pay someone to do it?
    SMGPFC Two Nipple General
  3. #3 Re: Need advice now on buying gtp
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    the passenger tire is the power tire fyi so it could be from that or some one doing burnouts
    personally go for it and to a complete rebuild on the front end and engine
    look at the back area where the doors close thats a easy rust spot
  4. #4 Re: Need advice now on buying gtp
    Iowa
    I can do all the work my self.
    I noticed the strut nut moving side to side when the tires turned and when pushing the car down and loading the suspension.
    I noticed surface rust on the rockers but very minimal. It is hard to tell on these cars with all that plastic side skirts.
  5. #5 Re: Need advice now on buying gtp
    Charles City, IA
    If it is a good runner and looks good I say go for it. Get the parts you need and then some extras that you dont ie mods. For the coupler go to Welcome To TDC Racing it will last the life of your supercharger.
  6. #6 Re: Need advice now on buying gtp
    Iowa
    I'm just worried about getting another car that breaks me lol. I think it's a great price even with the mileage and work needed. Most I see go for twice that.
    Btw, nice to see some Iowegians on here lol.
  7. #7 Re: Need advice now on buying gtp
    these cars run forever and take a massive amount of abuse so long as you take care of the big things. i say do it.
  8. #8 Re: Need advice now on buying gtp
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    If the car's in that bad shape, then it probably wasn't taken care of very well. You never know what you'll find once you start taking it apart. By the time you're done, the cost of getting it running could be well over the cost of one in good shape. If it were me, I'd pass.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  9. #9 Re: Need advice now on buying gtp
    Charles City, IA
    Where in Iowa are you?
  10. #10 Re: Need advice now on buying gtp
    SE Level Member Mercenary's Avatar
    Sav
    As someone who was in a similar situation I would pass on it. I regret buying my GTP.
  11. #11 Re: Need advice now on buying gtp
    Wausau, WI
    as with almost any vehicle with that high of mileage there will be some issues with it. If the drivetrain seems solid and runs well(motor tranny cv joints) the rest is fairly minor as far as cost to repair. Any vehicle with this many miles just will not be maintenance free. I had to fix mine up some, but I did know this going into it. If you like the car buy it.....
  12. #12 Re: Need advice now on buying gtp
    Iowa
    The thing is I only have 2000 to spend so I know whatever I buy will most likely need work. Plus most gtp's are going for more but that is still with the same mileage in the same shape so I think it's a good deal but who really knows.
    I am in Ames.
  13. #13 Re: Need advice now on buying gtp
    Wausau, WI
    honestly, you wont know if it is worth it until after you buy it if there is anything wrong that you missed, but for a 2000 dollar budget you probably wont find a better deal for a gtp. I hope you have at least 1000-1500 dollars available to stick back into once you start fixing all of these issues..........if you dont then plan to drive a broken car, or dont buy it at all and get a cavalier........unfortunately it is all about the available funds to you.
  14. #14 Re: Need advice now on buying gtp
    Iowa
    well I'm planning on 1500 for the car and I can get the parts needed for round 500ish. If there is anything else wrong it will just have to sit for awhile.
  15. #15 Re: Need advice now on buying gtp
    Wausau, WI
    well if you do buy it........welcome to the GP club, welcome to the site and let us know if there is any info or tips that you would like to know.........Please read the safely modding your 3800 thread in the tech section.......very helpful and good to know even if you dont plan on modding your car. worth the time to read it. Good luck...
  16. #16 Re: Need advice now on buying gtp
    Donating Users mystic231's Avatar
    Michigan
    I'd buy it. I've seen multiple SE's listed around here for $4500 with 140-160k miles on them.
    Bingo. The left rear did this on my '98. The strut shaft hole in the mount was twice as big as the shaft.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  17. #17 Re: Need advice now on buying gtp
    Wausau, WI
    Quote Originally Posted by mystic231 View Post
    Yeah........but who would buy it for those prices? We all know that this is not worth it..........
  18. #18 Re: Need advice now on buying gtp
    GT Level Member GrandPrixGT00's Avatar
    New Jersey
    how about i sell u my 2000 GP gt 89k miles no problems just a couple dings from the person who had the car befpre me im lookin to buy a G6 thats why im selling it ill sell the car for $2700 its clean amd runs well u can see pics in the "Car picture" forum and just do a top swap u'd prob end up putting less money into it that replacing all that crap
  19. #19 Re: Need advice now on buying gtp
    Iowa
    Ya but you live a little far away lol.
  20. #20 Re: Need advice now on buying gtp
    Wausau, WI
    yeah.........plus it is above the 2000 that you wanted to spend total. And when you would be done you still would not have a gtp.....
  1. gtp buying guide
    By windycitygtp in forum General Tech Discussion
    Last Post: 01-18-2009, 09:09 PM
  2. Wow, can we talk her into buying a GTP
    By 03GPScottyd in forum Off Topic Discussion
    Last Post: 11-08-2008, 10:14 AM
  3. lookin at buying?
    By riceburner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-11-2008, 08:49 PM
  4. Buying a GTP
    By Rod in forum Introductions/Noob Questions
    Last Post: 06-21-2008, 09:43 PM
  5. Buying a DHP PT
    By Sabrewings in forum General Tech Discussion
    Last Post: 04-13-2008, 08:37 AM
