Thread: Best tools for hub assembly removal?
Results 1 to 8 of 8
  1. #1 Best tools for hub assembly removal?
    SE Level Member TronCarter's Avatar
    Kalamazoo, Michigan
    I need to replace a front wheel hub assembly on my '02 GTP. I am cool with the 36mm nut, brake caliper and bracket, and of course the wheel, but what is the best way to attack the three, almost impossible to get at, 13mm bolts that hold the hub assembly on? Impact wrench? 6-point sockets? Can you get a 1/2" drive socket in there? Any help or tips appreciated.
    Tron
  2. #2 Re: Best tools for hub assembly removal?
    SE Level Member trenaro's Avatar
    Feb 2009
    KC
    It's a little tight, but you can get them off with a 3/8" drive and 6 pt. Do a search, theres a couple of how-to's in here. It's actually a easy job.
  3. #3 Re: Best tools for hub assembly removal?
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    I need to do this as well on my 2000 GTP, but haven't started researching it yet. I've seen some "how to" posts online with pictures and video that make it seem really straightforward and pretty easy.
  4. #4 Re: Best tools for hub assembly removal?
    Banned - Busted For Scamming
    Feb 2009
    The fronts, like he said with a 13mm socket, you just take off the hub nut, then take out the 4 hub bolts from the back, disconnect the abs sensor and pull it off. Its the easiest way to get it done.
  5. #5 Re: Best tools for hub assembly removal?
    Charles City, IA
    Need a BFH if the hub is seized to the axle.
    SMGPFC Two Nipple General
  6. #6 Re: Best tools for hub assembly removal?
    Ohio
    They said it all. Its really a fairly simple task. u will also want a torque wrench to torque the axle nut back on when ur done. I dont remeber the number right off or id tell u the torque it needs to be at.
    00 GTP demodded and forsale
  7. #7 Re: Best tools for hub assembly removal?
    Charles City, IA
    goes to 159 ftlbs
  8. #8 Re: Best tools for hub assembly removal?
    Ohio
    ^ thanks for adding that
  1. wheel hub tools...
    By Jakegday in forum General Tech Discussion
    Last Post: 01-14-2009, 01:16 AM
  2. Scan tools
    By mattio in forum General Tech Discussion
    Last Post: 11-02-2008, 10:07 PM
  3. Daddy got new tools
    Last Post: 06-16-2008, 07:29 AM
  4. Tranny Tools Needed for Rebuild
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2008, 07:20 PM
