Thread: 3.1 L v6 to a GTP SUper charger, etc engine
Results 1 to 6 of 6
00grandprixgirl 3.1 L v6 to a GTP SUper... 07-17-2009, 10:04 AM
TCO Re: 3.1 L v6 to a GTP SUper... 07-17-2009, 11:01 AM
SuperSport Re: 3.1 L v6 to a GTP SUper... 07-17-2009, 11:08 AM
00grandprixgirl Re: 3.1 L v6 to a GTP SUper... 07-17-2009, 08:03 PM
blueguy Re: 3.1 L v6 to a GTP SUper... 07-18-2009, 10:08 AM
ASCStinger Re: 3.1 L v6 to a GTP SUper... 07-27-2009, 08:23 PM
  1. #1 3.1 L v6 to a GTP SUper charger, etc engine
    SE Level Member 00grandprixgirl's Avatar
    PA
    i got my 2000 prix in February... 1 week later the engine blew..replaced it beginning of march..now i have oil in my anti freeze, and the "low coolant" light keeps flashing at me.. it could be a head gasket, main cylider head, etc. it is less expensive around here to get a whole engine than just the heads,seals,gaskets,etc.. so i want to do an engine swap and turn my SE to a GTP. i need to know what all i need to swap? tranny, computer,?? thanks for any help you can give me
  2. #2 Re: 3.1 L v6 to a GTP SUper charger, etc engine
    You will need a whole new engine. The GTP engine is a 3800 (3.8 L) while yours is a 3100. You will also need the new PCM, most likely need a new tranny and probably new wiring harness. Plus, the SE axles will not be as strong as the GTP ones so they could easily break.
  3. #3 Re: 3.1 L v6 to a GTP SUper charger, etc engine
    GTP Level Member SuperSport's Avatar
    Michigan
    You might hae better luck just trying to find a decent shaped GTP. They can be had for about 3k nowadays.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  4. #4 Re: 3.1 L v6 to a GTP SUper charger, etc engine
    PA
    thats kind of what i figured...i guess i just will get another 3.1 and hope for the best.. should've known better when i found this car on vehix.com and it said it was a GTP and then travelled 75 miles there and saw it wasn't. but i liked the car and how smooth it was...100 miles later, it was dead
    HI!
  5. #5 Re: 3.1 L v6 to a GTP SUper charger, etc engine
    Yup...that's how they get ya...thick azz oil and you can't hear any sort of sounds...
    3100's are pretty easy to come by...if need be...
    Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
  6. #6 Re: 3.1 L v6 to a GTP SUper charger, etc engine
    SE Level Member ASCStinger's Avatar
    Jan 2009
    Rochester, NY
    you could always grab a 3100 block and cobble together an assortment of 3400/3500 heads/lim/uim/tb for some power gains
    The BEST Source For All Your GM 60ºV6 Needs would be an excellent resource if you were going to go that route
  1. super charger upgrade
    By Kluke in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-04-2009, 07:31 AM
  2. super charger
    By 00pontiac1971 in forum General Tech Discussion
    Last Post: 05-12-2009, 02:12 AM
  3. super charger display
    By toohott7718 in forum General Tech Discussion
    Last Post: 03-28-2009, 10:54 PM
