Thread: Guys who run slicks, step in......
Results 1 to 13 of 13
  1. #1 Guys who run slicks, step in......
    Moore, Oklahoma
    I have a few questions for you guys.
    What suspension parts do you mainly need to focus on when inpecting for wear? I'm guessing mainly the CV joints and A-arm bushings? Since i'm still on OEM GM CV joints with 170,000 miles on them, wondering if I should get some new ones.
    What launch techniques do you use? How about burnouts?
    Just trying to cover all bases. I want to drive to the track and drive home just fine. I've never ran slicks on a FWD car before so i'm trying to cover all the bases...
    Shawn W. Larsen
  2. #2 Re: Guys who run slicks, step in......
    CT
    I have a feeling with 170,000 on you front drive train your asking for problems with slicks. I'd suggest you get a few back up parts so you can limp it home in case anything happens.
  3. #3 Re: Guys who run slicks, step in......
    Jan 1970
    Maquoketa, Iowa
    I haven't got slicks for the car yet but...
    Techniques for launching:
    Pull up to the water box, spin the tires through to get them wet, roll past the water box. Set e brake on. While left foot on the brake, right foot on gas bring the rpms up and just slam the hammer down and maybe have someone spot you to see that both tires are spinning... Give the steering wheel a little shake back and forth while in burnout and then let the e brake go.
    When at the line, may or may not apply for s/c cars but for turbo cars you want the brakes to hold the car back as much as you can. To do this some people have pulled up to the line and when staged put the car in nuetral, give it a quick rev, hold the brake as far down as you can, shift to drive and then you can build more boost after you have raised the brake pressure up. From there on out its tires/air pressure/track surface and getting a feel for the pedal.
    170,000 miles, you may want to do a thorough inspection, or just find out at the track...lol
  4. #4 Re: Guys who run slicks, step in......
    TDCRacing
    Guest
    QTP's here
    I would not replace anything enless it has broken. I mean to a certain point the CV's can not wear out. As long as they have been properly maintained I don't see an issue with them braking.
    And FWIW I have never seen any CV's break except MAYBE one. And that was on the forums somewhere. And we don't have anything above the stock CV's strength wise anyway. Except the bogus ''aftermarket'' ones.
    Control arm bushings would be my first concern.
  5. #5 Re: Guys who run slicks, step in......
    TDCRacing
    Guest
    Quote Originally Posted by FoSHO99 View Post
    I would have to agree on the launching 100%
    Just dont floor it when you are at the line with the brakes held down. You would more than likley want to bring it up to around 1500RPM's Anything above that is going to be making a LOT of unwanted heat.
  6. #6 Re: Guys who run slicks, step in......
    Moore, Oklahoma
    Quote Originally Posted by dagger View Post
    Well, I have a built tranny so that base should be covered, at least its better than stock anyway. My main concern are the CV joints honestly.
    Shawn W. Larsen
  7. #7 Re: Guys who run slicks, step in......
    Moore, Oklahoma
    TDC, when you say properly maintained on the CV joints, what do you mean? I wasn't aware of any maintaince other than inspecting the boots and making sure there fine.
    BTW, i'm still on original boots. No tears, no green goo anywhere.
    Shawn W. Larsen
  8. #8 Re: Guys who run slicks, step in......
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Iron Indian View Post
    If your car isn't lowered they should be fine.
  9. #9 Re: Guys who run slicks, step in......
    Moore, Oklahoma
    Quote Originally Posted by TDCRacing View Post
    Yeah I know to stall it up. I've raced on street tires which sucks, never again.
    Hoping with some sticky slicks I can launch at a fairly decent RPM and get out of the hole. I'm thinking of trying 2,500-3,000 rpm launch. I do have 3.29s and a 3,000 stall so i'm sure this won't be easy. There used to be a guy out here years ago with a bolt on GTP/stock trans and on slicks he'd launch from 3,000 rpm, he'd litterally chirped and go, obviously not a high power GTP but enough to run into the mid-low 13s which was great for hardly any mods at all.
    Shawn W. Larsen
  10. #10 Re: Guys who run slicks, step in......
    Moore, Oklahoma
    Stock ride height thankfully...
    Shawn W. Larsen
  11. #11 Re: Guys who run slicks, step in......
    TDCRacing
    Guest
    That's exactly what I mean
    I am also on the stock boots and CV's
  12. #12 Re: Guys who run slicks, step in......
    Moore, Oklahoma
    Hummm, maybe i'm alright them.
    BTW, since you have a store and all, you by chance can't get QTPs for a discounted price can ya? Just curiois.......
    Shawn W. Larsen
  13. #13 Re: Guys who run slicks, step in......
    Moore, Oklahoma
    ttt
    Shawn W. Larsen
  1. Need to add more timing.... (step in Alky guys)
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2009, 12:07 PM
  2. Where to buy some Slicks?
    By Iron Indian in forum Tires & Wheels
    Last Post: 03-29-2009, 10:02 PM
  3. Nitrous Guys Step In!!
    By TDCRacing in forum General Tech Discussion
    Last Post: 06-04-2008, 05:38 PM
  4. Step by Step header install.. HELP!!!
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2008, 01:51 PM
  5. L26 Guys....Step on in.
    By Reptile in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2008, 07:50 AM
