Thread: Sunroof...
Results 1 to 3 of 3
  1. #1 Sunroof...
    Nov 2008
    Searcy,Arkansas
    I have went threw some pages and havent found a answer..so help or show me a link! lol. There is water stains on the cover to my sunroof and around it only on the driver side. It wasent like this when I got the car...I noticed it around Mayish. I know I have read something about a leak and check some hose...but I have no clue how to get to it or where to start! Here is some pictures might help. All I have is my phone cause my camera for some reason wont charge! grrr
  2. #2 Re: Sunroof...
    GTP Level Member SuperSport's Avatar
    Michigan
    Open your sunroof all the way, and look to the outside of the track the glass rides in, towards the front of the vehicle, there are holes that water travels down. Make sure those arent plugged with leaves. Mine had a bandaid sitting in front of the hole from the previous owner.
    Also, open your front doors and look for a single rubber tube on each side and make sure those arent plugged as well. (This is where the water from the tracks drain.)
    Good Luck.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: Sunroof...
    Donating Users mystic231's Avatar
    Michigan
    Adequate drainage is provided by a drain trough in the sunroof module which encircles the sliding window panel and leade to drain hoses located in each corner of the housing. In addition, a drain channel spans the rear of the sunroof module and directs water into the trough.
    The front drain hoses are routed down the windshield pillars and out the center of each pillar between the upper and lower door hinges. The rear drain hoses are routed down the C pillars.
    If a wet headlining is encountered, verify the drainage system is not plugged or disconnected. Us a pint container to pour water into the housing drain trough. If water flow is restricted, use compressed air to blow out any material plugging the drain system.
    To further check for disconnected drain hoses without removing the headliner, remove the sunroof control switch and the sunroof opening trim ring around the sunroof opening and lower the headliner as required.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  1. Sunroof
    By K1J1E2 in forum General Tech Discussion
    Last Post: 03-12-2009, 11:43 PM
  2. Help with sunroof!
    By kbwent in forum General Tech Discussion
    Last Post: 02-22-2009, 08:55 AM
  3. HELP! Sunroof
    By GTPluv in forum General Tech Discussion
    Last Post: 10-19-2008, 07:04 PM
  4. Sunroof issues
    By Mikel2k7 in forum General Tech Discussion
    Last Post: 06-28-2008, 11:27 AM
  5. Sunroof problem?
    By 99GPGT in forum General Tech Discussion
    Last Post: 04-25-2008, 10:40 PM
