Thread: Amp Wiring
Results 1 to 9 of 9
  1. #1 Amp Wiring
    Indy
    anyone know how to get 4 gauge amp wire thru firewall? found a grommet with a wire on the passenger side floor but there is no space to get another wire thru. what the least invasive way to get power to my amp?
  2. #2 Re: Amp Wiring
    Ohio
    poke a hole in that grommet u found an run the wire through there. the rubber for that grommet is stretchy enought that it wil just stretch right around your wire
    00 GTP demodded and forsale
  3. #3 Re: Amp Wiring
    Indy
    poke it with what. the wire is about quarter inch thick
  4. #4 Re: Amp Wiring
    CT
    That comes out, then there is a flimsy piece behind that. Take that huge part and cut out an area for the wire to go through. Basically just take a screw drive and push on one side of the square piece so you can pull the other side out.
  5. #5 Re: Amp Wiring
    Indy
    push it from the bottom of the car or floorboard side. is it hard to get back in.
  6. #6 Re: Amp Wiring
    Ohio
    i just shoved a coathanger through from the floorboard side
  7. #7 Re: Amp Wiring
    GT Level Member skidoojames151's Avatar
    seattle
    i took a metal rod and taped my wire to it with electrical tape and then pushed it through and then found it on the other side...easy!
  8. #8 Re: Amp Wiring
    Ohio
    Evactly what i do with the coat hanger^
  9. #9 Re: Amp Wiring
    Indy
    okay got that boot off and punched a whole thru the membrane but there is another wall of what i guess is another sound wall or whatever. what did you do about that last obstacle. i cant get anthing useful down in there to cut it.
  1. Need help wiring amp
    By jjwitty in forum Introductions/Noob Questions
    Last Post: 07-24-2009, 01:59 PM
  2. Wiring
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2009, 03:02 PM
  3. Please help!! EGR wiring
    By Red97GPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 11:30 AM
  4. Help with LED Wiring?
    By FastKatt in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2009, 10:28 PM
  5. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
