anyone know how to get 4 gauge amp wire thru firewall? found a grommet with a wire on the passenger side floor but there is no space to get another wire thru. what the least invasive way to get power to my amp?
poke a hole in that grommet u found an run the wire through there. the rubber for that grommet is stretchy enought that it wil just stretch right around your wire
poke it with what. the wire is about quarter inch thick
That comes out, then there is a flimsy piece behind that. Take that huge part and cut out an area for the wire to go through. Basically just take a screw drive and push on one side of the square piece so you can pull the other side out.
push it from the bottom of the car or floorboard side. is it hard to get back in.
okay got that boot off and punched a whole thru the membrane but there is another wall of what i guess is another sound wall or whatever. what did you do about that last obstacle. i cant get anthing useful down in there to cut it.
