Thread: Fuel Pump wiring diagram for 1996 3.4L
Results 1 to 3 of 3
  1. #1 Fuel Pump wiring diagram for 1996 3.4L
    Edison, NJ
    I'm having fuel pump issues with my 1996 Grand Prix LE with a 3.4L motor. The car has been stalling periodically after it warms up. Once is stalls, it seems as though it will not start until it cools off (once it took 15 minutes another time over nite). It is definitely due to lack of fuel because when it stalled I measured the fuel pressure at 0 PSIG and the engine always cranks. The problem is not the realy because when it would not start I swapped the fuel relay with the compressor relay with no change. My thought is that may be the oil pressure switch (low oil light just came on) or a heat soaked crank position sensor is not allowing the relay to energize the fuel pump. Does anyone have a wiring diagram for this vehicle or know what are all the safeties or switches that enable/disable the fuel pump relay?
  2. #2 Re: Fuel Pump wiring diagram for 1996 3.4L
    I live here. UR LOSN's Avatar
    Rockford, IL
    moved to correct section
  3. #3 Re: Fuel Pump wiring diagram for 1996 3.4L
    Edison, NJ
    Problem ended up being a bad fuel pump located in the gas tank. This seems to be a common problem for these cars.
  1. 02 speaker wiring diagram
    By duffinator775 in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2009, 11:29 AM
  2. Monsoon wiring diagram?
    By GiAnT4LYFE in forum Audio, Security & Visual Electronics
    Last Post: 04-30-2009, 03:34 PM
  3. Monsoon Amp Remote Wire and Speaker wiring diagram
    By Thatonepunkrawk in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 07:58 PM
  4. Wiring Diagram, Ignition/security system
    By boogsey in forum General Tech Discussion
    Last Post: 12-25-2008, 11:32 PM
  5. wiring diagram for 05 non monsoon
    By 05grndprix in forum Audio, Security & Visual Electronics
    Last Post: 10-07-2008, 02:56 AM
