Thread: Guages problem
Results 1 to 3 of 3
  1. #1 Guages problem
    SE Level Member PontiacGTPSE's Avatar
    Apr 2009
    Jackson, Michigan
    I was exploring and now i realize it wasn't a good idea, but I took my whole dash apart including the guages, well I thought that the guages just set to zero when the car was turned on. Apparently not. Does anyone know a way to set them. someone told he had heard maybe set them straight up and down and they would set to zero but any input would be appreciated. Thank You
    2001 GTP Special Edition
    Mods: Were Getting There...
  2. #2 Re: Guages problem
    Banned - Busted For Scamming
    Feb 2009
    youre going to have to hook up a scanner and drive the car and adjust the needles that way
  3. #3 Re: Guages problem
    Donating Users Liquifire's Avatar
    Wausau, WI
    you should have marked their location before removing them........too late now. only solution that I know of is get it up to operating temp.........put that gauge on where it normally is............etc. for those that you can. Not sure how to do this other than how it has already been mentioned above..........sorry.
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  1. Cyberdyne Guages?
    By Quicklynx in forum General Tech Discussion
    Last Post: 10-29-2008, 02:43 PM
  2. Guages
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-24-2008, 11:43 AM
  3. Guages
    Last Post: 02-29-2008, 04:36 PM
  4. A pillar and guages
    Last Post: 02-25-2008, 05:45 PM
