Thread: Oil filter preference
Results 1 to 6 of 6
  1. #1 Oil filter preference
    SE Level Member 07CrimsonGT's Avatar
    Apr 2009
    Oxford, Ohio
    What is the consensus regarding the use of the AC PF 52 as opposed to the recommended PF 47?
    Looks to me to be the same filter, just a bit longer. I am sure this topic has been covered in the past, I would appreciate any and all input.
    Don
  2. #2 Re: Oil filter preference
    They are for the 4.3 liter Vortec V6 IIRC. And yes, just a bit longer.
  3. #3 Re: Oil filter preference
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    i read somewhere (dont remember where/when) that someone was using the longer filter on their grand prix and they had dents in the bottom of it from something in the suspension hitting it.
    like i said, i dont remember where or when i read that, or if it was even true. just give you my "any and all" input
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  4. #4 Re: Oil filter preference
    Barksdale AFB, LA
    I've been using the longer filters for a while. No dents.
    It just gives you more filtering media so you get more efficient filtering and a possibly longer service interval if you're using a good quality oil.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Oil filter preference
    GTP Level Member Scimmia's Avatar
    QCA, IA
    In order for the filter to hit the subframe, the motor mount would have to be absolutely, completely shot. I've been running the PF52 size filter for ~100K now without any problems at all.
    2001 Buick Regal LS - Almost Stock
  6. #6 Re: Oil filter preference
    Apr 2009
    Oxford, Ohio
    Guys:
    Thanks for the comments. I have a stock of the 47's to get through before i make the swap.
    Don
  1. what filter is best?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2009, 11:50 PM
  2. Basic Mod Preference
    By xawahl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2009, 06:41 PM
  3. What K&N Air Filter To Use
    By SG2000GTP in forum General Tech Discussion
    Last Post: 06-01-2008, 06:00 PM
  4. Anyone have an S&B filter?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 04-12-2008, 07:18 AM
