Thread: Please help I keep having trouble with my 3.1L's fuel delivery
Results 1 to 8 of 8
  1. #1 Please help I keep having trouble with my 3.1L's fuel delivery
    Mertztown, Pennsylvania
    I have a 1991 Pontiac Grand Prix with a 3.1L. I have changed the O2 sensor, both coolant sensors, the IAC valve, the plugs and wires 10,000 miles ago, the vacuum line harness from the throttle body, the fuel pressure regulator, the fuel filter, cleaned the throttle body, put gas in from a good gas station, and a few others things that had to be changed cause the car started running like ****. Now, she is up to it again. She has 160,000 miles on her and I put to much money in to quit now. Here is the problem.
    First it started as surges at a very low rpm or at stops. The RPMs drop and go up to normal and drop, etc. It would be better in neutral. But now when i am cruising the engine starts to buck when I am on the gas and even when I am not. Also when the car sits and idles you can here from the exhaust she is not running properly. The engine light came on once for two minutes and it was a code 45 - O2 Sensor error (rich mixture indicated). You can even smell the car is running rich from the too much gas smell. The car will accelerate fine, but it will hesitate a time or two before taking off.
    If anyone can give me ideas on what could be wrong I would greatly appreciate it. I am thinking it might be a sensor or something like that. Someone told me to also get my fuel injectors cleaned since my fuel filter was found clogged a year ago and everything was cleaned after that except for the injectors since dirty fuel was going through the system.
    My fuel pump was tested and was found to be sending the right amount of pressure of fuel even though my fuel pump likes to make a whining noise. This problem is getting worse over the weeks and I can't figure it out and I bet it will be something stupid I forgot to think about so that's why I am asking. Thanks for your time
    - Brennah
  2. #2 Re: Please help I keep having trouble with my 3.1L's fuel delivery
    Wausau, WI
    mass air flow sensor?-just a guess
  3. #3 Re: Please help I keep having trouble with my 3.1L's fuel delivery
    Everyone thought that, but my Grand Prix does not have one. The car will kinda buck while cruising, but when i let off the gas it gets a bit better. Also when i get on the gas while it's doing it my car will accelerate fine. It's driving me nuts cause I love the car so damn much.
  4. #4 Re: Please help I keep having trouble with my 3.1L's fuel delivery
    Wausau, WI
    have you replaced the coil packs or coil?
  5. #5 Re: Please help I keep having trouble with my 3.1L's fuel delivery
    Wausau, WI
    are your voltages good as well?
  6. #6 Re: Please help I keep having trouble with my 3.1L's fuel delivery
    Jul 2010
    parma ohio
    I, am having same exact problem with my 91 se gp ,if you solved it please, contact me. I 'm leaning toward fuel injectors .
  7. #7 Re: Please help I keep having trouble with my 3.1L's fuel delivery
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Pull the vac line to the Fuel pressure regulator see if gas comes out. Otherwise maybe a injector pintle is stuck? Maybe run some injector cleaner threw see what happens
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  8. #8 Re: Please help I keep having trouble with my 3.1L's fuel delivery
    Jul 2010
    parma ohio
    This car is still sitting,im driving my truck in the mean time.I've replaced everything ,its giving me a code for ,IDLE SPEED CONTROL CIRCUIT/ i cant find what the chilton's mean
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. Tipping the wing delivery guy
    By David99GTP in forum The Rant Forum
    Last Post: 02-25-2008, 09:24 AM
  4. Fuel Trim trouble
    By GTP Mike in forum PCM Tuning
    Last Post: 01-21-2008, 08:32 PM
