Thread: Coolant Elbows for 2000 GTP
Results 1 to 6 of 6
nickbuol Coolant Elbows for 2000 GTP 07-21-2009, 12:05 PM
SDGTP99 Re: Coolant Elbows for 2000... 07-21-2009, 12:15 PM
nickbuol Re: Coolant Elbows for 2000... 07-21-2009, 12:18 PM
SDGTP99 Re: Coolant Elbows for 2000... 07-21-2009, 12:23 PM
Lawngoose Re: Coolant Elbows for 2000... 07-21-2009, 12:26 PM
Iron Indian Re: Coolant Elbows for 2000... 07-21-2009, 10:51 PM
  1. #1 Coolant Elbows for 2000 GTP
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    I am getting myself Dex-Cool free later today and I thought that I might replace the coolant elbows since I hear that they are problematic. Where are they located (is it obvious)?
    I am sitting at work right now and can't check until later today...
  2. #2 Re: Coolant Elbows for 2000 GTP
    Wichita
    The Waterpump
  3. #3 Re: Coolant Elbows for 2000 GTP
    Apr 2008
    Marion, Iowa
    Are they easy to replace?
  4. #4 Re: Coolant Elbows for 2000 GTP
    Wichita
    Hafta take a lot of stuff off to get to the pump & take these off but its not too difficult. Great idea to replace them though.
  5. #5 Re: Coolant Elbows for 2000 GTP
    Outer Space
    I bought some from Advance auto, they come in a pack of 2.
    02 GTP 13.6 @ 100mph - SOLD
  6. #6 Re: Coolant Elbows for 2000 GTP
    Moore, Oklahoma
    You don't have to take the water pump off to replace the coolant elbows........ all you remove is the alternator and the heater bypass ( the thing the 2 heater hoses connect to). IIRC its held on with 4 bolts and pulls off, one elbow is on the bottom side, the other goes from the bypass to the LIM. Pretty straight forward and easy to do not to mention good maintaince.
    Just remember, when you pull off the bypass you'll most likely break off the ends of the old elbows. Be sure to dig out the plastic piece and oring before installing the new elbows, and use some sort of grease on the new elbows....
    Shawn W. Larsen
  1. Which coolant to use...
    By Rickochet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:34 PM
  2. Replacing uim and lim 97 gp 3.8 (Coolant Elbows?)
    By Onthebrinc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2008, 05:27 PM
  3. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  4. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
  5. How much coolant?
    By chitownchevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:30 AM
