Thread: Building up a 3800... how much did it cost??
Results 1 to 13 of 13
  1. #1 Building up a 3800... how much did it cost??
    Moore, Oklahoma
    I thinking about building up a 3800 soon, not sure yet if i'll assemble the bottom end myself or not, most likely probably not. For the bottom end I plan on using 9.5:1 Diamond forged pistons uncoated, L67 rods (since i've seen way more L32 failures than L67), a new crank (again, seen alot of failures from turning these), ARP hardware most likely and thats all I can think of at the moment. Not sure if I should go with Clevite bearings or stick with stock, not sure on a cam either.
    Whats your setup? What did it cost you? And no, i'm not interested in a junkyard short block. I'd rather build something potentially stronger than stock.
    Shawn W. Larsen
  2. #2 Re: Building up a 3800... how much did it cost??
    ...why? the stock bottom end holds up to pretty much anything you throw at it. i dont see a need to build.
  3. #3 Re: Building up a 3800... how much did it cost??
    GT Level Member tylerbinski's Avatar
    Canada
    its expensive.
    I rebuild my motor this winter.. took EVERYTHING out, sent the block off the the hot tank for a clean and wash.
    Clevite bearings (cam, crank, rod)
    polished crank (it was in spec and i didn't want to grind it down
    re-used stock L67 rods (forged rods from 2005 would be nice)
    new piston rings
    ARP (main studs, head studs and rod bolts)
    balancer shaft removal
    double roller
    XP cam
    self-ported heads and gasket matched LIM
    headers
    LS6 springs, viton valve seals, modded retiners, comp cam valve locks
    lapped the valves for better sealing
    FELPRO head gaskets
    exhaust manifold studs
    tap/chased all threads
    gasket kit from zzp
    custom valve covers
    10.3mm wires from ZZP
    65# injectors
    St3 ported blower (silencer slits welded up) self- polished case
    full size intercooler
    North Stare throttle body
    Throttle body heat shield
    4" JMB Fender well intake
    full 3" exhaust to the back
    and....
    Basically it was expensive... itwas a long process, it was fun, learned so much..
    But..
    its one of those things i've now crossed off my list, prob wouldn't do again due to the time it takes and the flak I got from the GF..lol
    prob cost 5-7 grand
    Motor has about 2000 km on it now and runs good.. still working on the tune and it gets better every day
    What would i do differently?
    I'd paint the blower because it took me like 100 hours to polish it and is a "rough" polish... ate up too much time!
  4. #4 Re: Building up a 3800... how much did it cost??
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Quote Originally Posted by Iron Indian View Post
    Shawn - you probably already know all of this, but just get an L36 shorty - you can get them for ~$250 all day long.
    Tank it and polish the crank - ~$125-ish
    Deck it - ~$75-ish
    Resurface heads - ~$60-ish
    Valve job - new seals - ~$150-ish
    Clevite bearings (yes ) - ~$22
    Main bolts (I wouldn't mess with studs - because if you do, then you "should" get it align-bored, too.) I would use studs for the heads, though - and I did.
    Mains - ~$50
    Head studs - $80
    Rod bolts - ~$100
    All new gaskets/seals, etc - ~$170-ish (full gasket set from ZZP is $160)
    Cam - gray area here - VS or XP is tried and true, but it's all about preference. ~$320
    Diamond 9.5:1's - ~$700-$900
    I've already decided that my next GP will be turbo.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  5. #5 Re: Building up a 3800... how much did it cost??
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    May i suggest steering away from the diamond pistons.
    They have a short skirt on them and after a few miles they will be nice and broke in, causing your car to sound like a diesel.
    Plenty of aftermarket pistons out there that would be a better investment.
    Engineering the impossible.
  6. #6 Re: Building up a 3800... how much did it cost??
    Quote Originally Posted by Merlin View Post
    This is sometimes true - but not always. Certainly a good point to consider. I know in LSx applications - and other SBC instances as well - they come with an offset pin - specifically to address the noise issue. I know of 1 GP owner with diamond pistons - and he has (at least) several thousand miles and numerous track passes on them - no piston slap.
    -Swash
  7. #7 Re: Building up a 3800... how much did it cost??
    May 2008
    Broken Arrow, OK
    I know of a wbody owner and a 3.8l f body owner that have the worst piston slap i have ever heard.
    They are hit and miss. I would spend 200 more and not take the gamble.
  8. #8 Re: Building up a 3800... how much did it cost??
    Moore, Oklahoma
    L67s and L36s are far from bulletproof. I'd rather build something personally. Too many people are scaried to build these motors and I don't know why. I don't want the cheap way out.
    I'd rather build a good solid foundation that last for years, instead of replacing short blocks every season (like some people tend to do). Thats my opinion...
    Shawn W. Larsen
  9. #9 Re: Building up a 3800... how much did it cost??
    Moore, Oklahoma
    Quote Originally Posted by Swash View Post
    Deck it - ~$75-ish
    Mains - ~$50
    Head studs - $80
    Rod bolts - ~$100
    -Swash
    Good info, thanks....
    Shawn W. Larsen
  10. #10 Re: Building up a 3800... how much did it cost??
    Moore, Oklahoma
    -Swash
    Good info, i'll keep that in mind if I go with forged Diamonds. I've also heard with the diamonds, don't go with the coated version. Something to do with tolerence? I donno I just heard uncoated was the way to go with diamonds.....
    Shawn W. Larsen
  11. #11 Re: Building up a 3800... how much did it cost??
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    bump ( so i can subscribe and be updated on this thread )
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  12. #12 Re: Building up a 3800... how much did it cost??
    May 2008
    staten island,NY
    i run an L32 now because of the coated pistons and powdered rods. brand new GM
    timing set, new rings bearings, etc. there are no reliable timing sets so i didnt go cam and kept my roller rockers. ive said it before, the tune is the most important piece to these cars. a crappy tune will break rods and destroy diamond pistons in no time. my build cost me 500 for the shortblock, 300 for the remaned heads, 1200 to rebuild it and put it all together
  13. #13 Re: Building up a 3800... how much did it cost??
    Moore, Oklahoma
    Quote Originally Posted by QwikGT View Post
    Tuning is definatly the key with any build. So many learn the hard way though. I want the Diamonds for extra durability. They are without a doubt stonger than stock L67/L32.
    You right about the timing sets, with all the problems out there i've honestly thought about just sticking with rockers for realibilty.
    Shawn W. Larsen
  1. building and exhaust help
    By msukid68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2009, 04:32 PM
  2. Building a Kit Car with 3.8 supercharger need HELP.
    By lambokit in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2009, 09:14 PM
  3. Considerations for building a Track use GTP?
    By Quicklynx in forum Brakes/Suspension/Chassis
    Last Post: 09-03-2008, 03:30 PM
  4. Building Cold Air
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 09:33 PM
  5. please help me! building motor
    By notagtp01 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-27-2008, 08:00 AM
