Thread: can you add HUD to 99 gt?
Results 1 to 3 of 3
  1. #1 can you add HUD to 99 gt?
    SE Level Member Roanokegprix's Avatar
    Roanoke Va
    just wondering if its possible to add heads up display to a 99 gt?
  2. #2 Re: can you add HUD to 99 gt?
    GT Level Member BoostedComp's Avatar
    Youngstown
    i believe all cars till 2000 have the harness to be plug and play. all you would need is the dash bezel and the actual hud unit and switch. but to be sure... you can take off the front most dash piece and see if the harness is there
  3. #3 Re: can you add HUD to 99 gt?
    Wausau, WI
    I was also under the impression that the HUD harness was installed in all GP's for those years(not sure if on all models, but for GT's and GTP's maybe even SE's?) Please correct me if I am wrong
add, hud
