Thread: BBV adjustment = +2psi !
Results 1 to 18 of 18
  1. #1 BBV adjustment = +2psi !
    Donating Users
    Plainfield, IL
    ok so awhile back i closed the bbv like an idiot and realized it was a mistake and tried to get it back to stock....so i recently got a mechanical boost gauge in and i never saw more than 6 psi.....then i was thinking maybe i adjusted the bbv to high and im bleeding off boost when im not supposed to be....lowered it a lil today and BAM +2psi in 5 mins haha kinda a nice 8psi kick for a stupid correction....but then on my way home tonight i raced a **** can civic from a 30 roll (dont need to tell the results as they are obvious) and when my tranny down shifted with the pedal floored i got 9psi for a second....is this possible im still running a 3.8 pulley.....i was shocked i get a steady 8psi now but sometimes i see 9psi why is this....
    still can't believe i was losing 2 psi thanks to zzp's tech section
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: BBV and Bam
    TDCRacing
    Guest
    Gald you got that issue fixed. Now go tear up some stuff.
  3. #3 Re: BBV and Bam
    9 psi on a stock pulley seems a bit much, I was gonna say since you have headers it would be more like 4-5psi...but who knows LOL
  4. #4 Re: BBV and Bam
    Donating Users
    Plainfield, IL
    at WOT i get 8psi all day...am i just lucky lol?
  5. #5 Re: BBV adjustment = +2psi !
    Donating Users blowfishRus6's Avatar
    g.a.
    i can still see full boost with headers and rockers, but its not till high rpms. mid rpms it probably around 5 going off the DIC.
    but i also have my bbv raised, when i lower it i too see more boost. but i could not tell you the exact amout.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: BBV adjustment = +2psi !
    Banned - Busted For Scamming
    Feb 2009
    raising or lowering the actuator has nothing to do with boost amount, only how fast the bbv actually closes.
  7. #7 Re: BBV adjustment = +2psi !
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Unless it's adjusted too high and can't close completely, which I'm guessing was the case for the OP.
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: BBV adjustment = +2psi !
    Donating Users
    Plainfield, IL
    Quote Originally Posted by Scimmia View Post
    thats exactly what was happening....it was still bleeding off boost at WOT....
  9. #9 Re: BBV adjustment = +2psi !
    Donating Users Liquifire's Avatar
    Wausau, WI
    stupid question............does bbv= blower blow off valve?Sorry......go easy on the newby(me)
    98 GTP Coupe- 180* T-stat, GMPP Front Sway Bar, Dual Aeroforce Interceptor's, TDC FWI, TDC Taylor 10.4's, ZZP SS Plog, ZZP 3" SS catted DP, ZZP MPS W/3.4, AL104's gapped @.055, 3800Perf. PCM
  10. #10 Re: BBV adjustment = +2psi !
    Wausau, WI
    or blower bypass valve?
  11. #11 Re: BBV adjustment = +2psi !
    Feb 2009
    yea boost bypass valve same thing
  12. #12 Re: BBV adjustment = +2psi !
    g.a.
    bypass valve.
    if i lower mine it gets into boost faster and boost higher in the mid rpm and is full at high rpms. when raised its slower to get into boost, less at mid rpm range and it kinda bounces off the full amount at high rpms.
    but i hate when its lowerd how it gets into boost everywhere. barley hit the gas and its boosting.
    its slow.
  13. #13 Re: BBV adjustment = +2psi !
    Feb 2009
    ahhhhh ic
  14. #14 Re: BBV adjustment = +2psi !
    Enid
    New here so go easy, im not getting full boost all the time like i use to. Could that be the bbv not working properly? Should i adjust it or whatever?
  15. #15 Re: BBV adjustment = +2psi !
    GT Level Member JbrownGTP's Avatar
    Colorado
    How exactly do you raise/lower the bbv? I have actually never played with the thing so is it easy to do?
  16. #16 Re: BBV adjustment = +2psi !
    Quote Originally Posted by JbrownGTP View Post
    there are 3 bolts you loosen. then you can move it but leave it where it is stock IMO.
  17. #17 Re: BBV adjustment = +2psi !
    Donating Users
    Plainfield, IL
    x2 DO NOT TOUCH IT haha i regret moving mine you can never get it back to where it originally was....although i did get lucky....at the top end of 1st gear i peak at 9psi....no lies ill have to record it....i wonder is 9psi is a stock pulley record...its weird tho i get 7 psi steady when i floor it and as the rpms climb the boost climbs 2 more pounds before the shift
  18. #18 Re: BBV adjustment = +2psi !
    g.a.
    mine builds boost with the higher rpms also. but i dont know exactly what it is. i need a boost gauge....
    its slow.
