hey guys so i been hearing a popping noise when i go up curbs or come to a hard stop....i was on a site looking at the MSP poly mounts and noticed in the install instructions that the lips on the edges of the mounts had a longer and shorter edge...longer faces the motor and shorter faces the ground....i installed some used zzp poly mounts one day in a rush before work and i went back tonight to check to see if i did the longer/shorter edges correctly....turns out one of the mounts i did wrong and the mount had play up and down due to the shorter edge leaving space ... do you think this was the culprit to the popping issue or i was thinking loose cradle bolts....i havent drove yet since i corrected the mount just wondering yours guys opinion on whether or not you think that mount would make so much noise wen put in wrong like that
