Thread: weird noise from supercharger/belt area
Results 1 to 5 of 5
  1. #1 weird noise from supercharger/belt area
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    today my car started making a whirring/whining noise today from the supercharger area. at first i thought it was a bad belt or something but then it started to get louder and now on top on the whining/whirring noise it almost sounds like something is grinding together. I checked the supercharger oil and the motor oil levels and they were fine. Could it be a bad pulley or something like that?
  2. #2 Re: weird noise from supercharger/belt area
    bourbonnais, il
    im actually having the same problem. i thought it could just be the bearings in the pulley system....
  3. #3 Re: weird noise from supercharger/belt area
    Take the blower belt off. If it persists then it isn't in the supercharger drive pulleys/tensioners.
  4. #4 Re: weird noise from supercharger/belt area
    Minnesota
    If you disconnect the Supercharger belt and the noise goes away, then the problem is within the Supercharger. If it sounds like a lot of marbles rolling around inside the Supercharger, then the Supercharger has a problem. You can either purchase a new supercharger, OR; there is a repair kit available on E-bay and elsewhere that replaces the joints inside that are worn out and broken. Last time I checked it sold for about $150-160.
    That is the simplest explanation.
    Good Luck!
    Ralph
  5. #5 Re: weird noise from supercharger/belt area
    Quote Originally Posted by Rebelwocause View Post
    Good Luck!
    Ralph
    Buy a new supercharger? No way. If it sounds like marbles then or rocks then it is the coupler...couplers run about $20-$30 and then get new oil which is about $10-$20...so MAYBE $50...no where NEAR $150-$160.
  1. weird noise
    By c32k05 in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 10:47 AM
  2. weird noise cutting out
    By 01gtpfargo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2009, 12:27 PM
  3. Weird noise problem!
    By GTP4 in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2009, 11:41 AM
  4. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
  5. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
