Thread: how to remove a 97 gp transmission?
Results 1 to 7 of 7
1997gp how to remove a 97 gp... 07-05-2009, 05:25 PM
blueguy Re: how to remove a 97 gp... 07-05-2009, 09:47 PM
chrisb Re: how to remove a 97 gp... 07-05-2009, 10:31 PM
blueguy Re: how to remove a 97 gp... 07-05-2009, 11:15 PM
DanGTP Re: how to remove a 97 gp... 07-06-2009, 02:56 AM
blueguy Re: how to remove a 97 gp... 07-06-2009, 04:07 PM
DanGTP Re: how to remove a 97 gp... 07-07-2009, 11:26 AM
  1. #1 how to remove a 97 gp transmission?
    atlanta
    hi i got a 1997 gp non supercharge i would love some help on how to remove the tranny.thanks alot!!
  2. #2 Re: how to remove a 97 gp transmission?
    Very carefully.
    Actually there is quite a bit involved in doing it...as you have to drop the entire cradle out from underneath the car.
  3. #3 Re: how to remove a 97 gp transmission?
    Donating Users chrisb's Avatar
    Bucyrus, OH
    ^^^HaHa what he said!! I wouldnt try from the bottom unless i had a lift. ill stick with pulling the engine then tranny or both at the same time from the top.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  4. #4 Re: how to remove a 97 gp transmission?
    Quote Originally Posted by chrisb View Post
    It really isn't too bad...done it a few times...you just gotta have it on jack stands and have a good jack to lower the transmission and a brace to hold the motor up top
  5. #5 Re: how to remove a 97 gp transmission?
    Feb 2008
    Not to pee in your Wheaties, blue, but I prefer the top-pull method. It gives one a chance to clean the engine while it's out of the car and the bay while it's empty.
    It just depends on what equipment you have to work with. If you have a set of tall jack stands and an engine support of some sort, then dropping it out of the bottom is the way to go.
    But, if you have a cherry-picker and an engine stand, pulling the engine first, out the top, will work.
    My best bit of advice: Beware of the B**** bolt. It's the one bolt holding the engine and tranny together that is facing the opposite direction as the rest. The best way to get to it is with a crap-ton of extensions through the passenger wheel well along the top of the 'tail' shaft of the tranny.
  6. #6 Re: how to remove a 97 gp transmission?
    Quote Originally Posted by DanGTP View Post
    It's ok...I like Crunch Berries anyways
  7. #7 Re: how to remove a 97 gp transmission?
    Feb 2008
    So.... Who's Wheaties did I pee in, then???
  1. how to remove a 97 gp transmission?
    By 1997gp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2009, 12:10 AM
  2. How to remove oil pan
    By CheeseWithMyWHINEplz in forum General Tech Discussion
    Last Post: 07-01-2009, 01:54 PM
  3. how do i remove the transmission
    By EMerola in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 12-09-2008, 07:28 PM
  4. Can't remove key
    By GrandPrixlbc in forum General Tech Discussion
    Last Post: 08-08-2008, 06:30 PM
  5. How Can I Remove This ?
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 04-23-2008, 01:18 PM
