Thread: AC only takes 7oz of freon?
Results 1 to 4 of 4
  1. #1 AC only takes 7oz of freon?
    GTP Level Member SuperSport's Avatar
    Michigan
    I had a shop evacuate my freon and they tried to replace it, and it only took 7 oz of freon. So they evacuated it again, and tried to replace it again, and it still only took 7oz. And I know it needs 2.25lbs. They said something in the system may be plugged. The vents blow semi-cool, and the drivers side hardly blows cool at all. They didnt charge me for the service, and now Im wondering where these systems commonly plug up? Or is something else wrong? Thanks.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  2. #2 Re: AC only takes 7oz of freon?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    whoa there! your putting FREON in a 2001????
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  3. #3 Re: AC only takes 7oz of freon?
    Charles City, IA
    ^ that is pretty hard to do being that the fittings are different. There are tons of things that could be clogged. Have the shop pull a vacum on your system then try to charge it or just have the shop try to charge it. It is easier to charge when the system is in vacum.
    SMGPFC Two Nipple General
  4. #4 Re: AC only takes 7oz of freon?
    Michigan
    Thats what they did. They used the machine. They said it held vacuum, but when they tried to refill it with r134a while in vacuum, it would only take 7 oz. Hopefully I can somehow narrow down where it is clogged.
  1. Engine takes too long to idle
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-18-2009, 12:07 AM
  2. my car takes a long time to switch frm gear 1 to 2.
    By krazyog1 in forum 04+ Specifics
    Last Post: 03-19-2009, 12:02 AM
  3. Car takes two or three tries to start.. once warmed up starts fine.. Any info?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2009, 03:42 PM
  4. What takes longer? Heads/Cam or Engine Swap?
    By t24moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 06:38 AM
