Thread: Electronics/Google Gurus step in!
Results 1 to 20 of 23
  1. #1 Electronics/Google Gurus step in!
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    I'm looking for a source for these AMP/Tyco Electronics parts. Any of them will do. I've found a few places that will ship me only 20 of them (as opposed to spools of 30000+) but most of them have a minimum order of at least $30. I only need 20 of them or so which usually is about $.15/ea for a total of $3.00. Anybody have any good sources for this stuff?
    173633-1
    173633-2
    175029-1
    175029-2
    173633-3
    175029-3
    173645-1
    173645-2
    175030-1
    175030-2
    173645-3
    175030-3
    175207-1
    175208-1
    345210-1
    345212-1
  2. #2 Re: Electronics/Google Gurus step in!
    Saraland Alabama
    have you checked mouser? I've used them for led's and never had an order over $10 I don't think
  3. #3 Re: Electronics/Google Gurus step in!
    Williamsport, PA
    yea, mouser doesn't carry these. That was the first place I looked. I just ordered some other pins from them a few weeks back and it went great. I'm bummed they don't have these.
  4. #4 Re: Electronics/Google Gurus step in!
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
  5. #5 Re: Electronics/Google Gurus step in!
    Williamsport, PA
    Hmmm, I looked at newark but apparently, I missed the 1 part number they cary that doesn't require thousands be ordered at once!! Thanks again Toasty. The one they have is for 24-22 awg wire and I was hoping to find some for 18-22awg. Any other good sources??
  6. #6 Re: Electronics/Google Gurus step in!
    SW Chicago Suburbs
    whatever the second p/n is they can get, but it's like a 6 week lead time.
    i didnt look at gauges
    check Audio and Video, Computer Parts, Batteries, Cable and Wiring at MCM Electronics too
    a sister of newark
  7. #7 Re: Electronics/Google Gurus step in!
    Williamsport, PA
    the 2nd part number is the same gauge wire, just uses a different contact material... the first is brass and the 2nd is phosphor bronze.
    Don't see any of them on the second site you listed.
  8. #8 Re: Electronics/Google Gurus step in!
    SW Chicago Suburbs
    hrmm
  9. #9 Re: Electronics/Google Gurus step in!
    GT Level Member BackInBlack's Avatar
    Vermont
    Digikey? Ebay?
    The GPs are long gone...
  10. #10 Re: Electronics/Google Gurus step in!
    SW Chicago Suburbs
    whatcha workin on that uses tyco connectors, anywhoo?
  11. #11 Re: Electronics/Google Gurus step in!
    Oklahoma
    An upgraded and much improved flux capacitor. Now runs on cooking oil.
  12. #12 Re: Electronics/Google Gurus step in!
    SW Chicago Suburbs
  13. #13 Re: Electronics/Google Gurus step in!
    Williamsport, PA
    working on my HUD install still....
  14. #14 Re: Electronics/Google Gurus step in!
    SW Chicago Suburbs
    Quote Originally Posted by TyroElite View Post
    are you trying to match a connector already in the car, or just adding a male/female plug?
  15. #15 Re: Electronics/Google Gurus step in!
    Williamsport, PA
    I'm trying to match up a connector that is already there. I have otherways of doing it but I was trying to find a way to make it plug and play.
  16. #16 Re: Electronics/Google Gurus step in!
    Saraland Alabama
    sounds like that is more work though
  17. #17 Re: Electronics/Google Gurus step in!
    SW Chicago Suburbs
    Quote Originally Posted by archemedes View Post
    sometimes more work is better in the end!
  18. #18 Re: Electronics/Google Gurus step in!
    SW Chicago Suburbs
    could you possibly use the one terminal that i found, and make it work with the slightly larger gauge wire? (crimp as well as possible, and use a little dab of solder to secure it?)
    i'm just VERY surpised to see a tyco connector inside a GM vehicle... it is stamped tyco, right?
  19. #19 Re: Electronics/Google Gurus step in!
    Williamsport, PA
    no tyco stamp but I looked up the part number from the connector diagram and that's what I came up with.
    I think I will try using the small one that you found since its all I've got. Its the HUD control signal wires so I could probably use a small gauge wire and be OK.
    I like doing things the right way even if it is a a little more work. If the tabs I find don't work out, I'll probably go with just finding some other 5 or 6 pin connector and use that instead.
  20. #20 Re: Electronics/Google Gurus step in!
    SW Chicago Suburbs
    can you post up the connector diagram you've got?
    i suppose there's a first for everything, but i have NEVER seen a tyco connector in a gm car....
  1. South Florida GPs step in!
    By flexnix in forum Southeast
    Last Post: 12-31-2008, 12:08 AM
  2. BlackJack people, step in (AT&T)
    By 3800SE in forum Off Topic Discussion
    Last Post: 05-29-2008, 11:19 AM
  3. White GP's please step in
    By TJs97 in forum Visual/Body Modifications
    Last Post: 02-16-2008, 05:14 PM
  4. Those with XP and VS cams step in
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 01:13 PM
  5. 2000 owners, step in
    By 3800SE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2008, 09:03 PM
