Thread: Car Hesitates When Floored
Results 1 to 17 of 17
  1. #1 Car Hesitates When Floored
    Saint Clair Shores
    I recently had a bad injector replaced, added a cold air intake, new plugs and wires and the car is solid until it's floored. When floored it hesitates on again and off again, its feels like the engine is starving for something like air or fuel. I took it to a mechanic and he "THINKS" its the MAF sensor since everything else has been replaced and there isn't a check engine light on. Has anyone else ever had this problem? Please let me know before I drop $300 on a new JET MAF sensor.
    Thanks!!
  2. #2 Re: Car Hesitates When Floored
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    Have you tried the basics like cleaning the MAF and throttle body?
    Also I think you can get GM MAF sensors for around 170$.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  3. #3 Re: Car Hesitates When Floored
    Banned - Busted For Scamming
    Feb 2009
    MAF for sure. see if you can get one at the junkyard instead
  4. #4 Re: Car Hesitates When Floored
    Feb 2009
  5. #5 Re: Car Hesitates When Floored
    SE Level Member BigG's Avatar
    St. Louis
    Check the TB an MAF screen to see if any debris from yur CAI install, is blocking the air flow.
  6. #6 Re: Car Hesitates When Floored
    Saint Clair Shores
    I cleaned the MAF and car still hesitates when floored or on freeway. I purchased a used MAF for $50 because I believe mine is just shot. I should have it in a day or two, hope it works!!
  7. #7 Re: Car Hesitates When Floored
    Feb 2009
    yea, usually if you clean it, alot of times it doesnt help
  8. #8 Re: Car Hesitates When Floored
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    I'd be curious as to what type of air intake you used. And...how much did you oil it?
    Because that symptom is text-book MAF sensor issue.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  9. #9 Re: Car Hesitates When Floored
    Saint Clair Shores
    New (slightly used) MAF is installed and didn't change a thing, now I'm becoming a little irritated. It's a K&N CAI and I didn't oil it at all?? I didn't know you had to??
    The car also barely has any power when at high speed, it really feels like something is clogged but I have checked everything in the CAI, MAF and TB. The other day I got on it and the check engine light flashed a few times and then went off??
    Anyone know a good GP mechanic in the Detroit area?? I need to get this beast back to full strength!!
  10. #10 Re: Car Hesitates When Floored
    If the SES light flashed most of the time that means it is a misfire...get the code pulled for sure.
  11. #11 Re: Car Hesitates When Floored
    St. Louis
    Have yu got the original Cat on there? Check to see if it's plugged up.
  12. #12 Re: Car Hesitates When Floored
    Quote Originally Posted by BigG View Post
    It is an '04...most only cat problems ever were on 01-02 L36 cars.
  13. #13 Re: Car Hesitates When Floored
    Apr 2009
    Baton Rouge, Louisiana
    Well thats an irritating problem indeed. Here ya are on the highway and ya wanna open that beast up. Show every one whats ya got, right. So ya push down on the accellerator only to get an annoying sputtering hesitation. Well it really isn't an air thing in this case, at least not by itself. Thats why changing the MAF didn't help. I think the problem is fuel delivery in the form of pressure. When you stomp on the gas you need more refined pressure to deliver the right atomization of fuel to the injectors, in turn the proper fuel pressure mixed with air to properly atomize the fuel for a clean burn and a hot one at that for hard accelleration. I think you might want to check your fuel pressure regulator it maynot be functioning properly under hard acelleration. TBS could be acting up too. Keep this in mind bad MAF sensors don't always cause such drivabilty problems as you described. Hope this helps. Let us all know what it turns out to be.
  14. #14 Re: Car Hesitates When Floored
    St. Louis
    Yu'd save yurself a lot of trouble, if yu'd just get some one to scan it. If yur problems, started after yu had the work done; its probably connected some how. Did yu get get that CEL checked?
  15. #15 Re: Car Hesitates When Floored
    Saint Clair Shores
    I've had it scanned numerous times before, that was the first thing I did and nothing came up. Anyway, I installed a new ZZP 1.0 PCM and my problem is fixed, what an amazing difference!!
  16. #16 Re: Car Hesitates When Floored
    Quote Originally Posted by 04GTPeeingOnU View Post
    I feel sorry for you and your car.
  17. #17 Re: Car Hesitates When Floored
    St. Louis
    I'm glad yu got it fixed. But, I didn't mean scan just to look for codes; but to look at the sensor readings. Timing, A/f ratio, MAF frequencies,ect.ect., to see wat changes when it loses power.
