Thread: Quick question before i run to autozone.
Results 1 to 7 of 7
  1. #1 Quick question before i run to autozone.
    SE Level Member pontiacgp759's Avatar
    Feb 2009
    Ada, OH
    First off, My car never came with an owners manual and my A/C is not very cold. For some reason the passenger side seems colder than the driver's side. Overall, the a/c is pitiful. I'm thinking i'm low on freon possibly? Anywho, back to the subject of not having an owners manual, does my car take r-132? Also, I just took a look under the hood. Of the two pressure lines, which is high and which is low? The caps are not marked. There is one by the drivers side firewall and another on the drivers side where my intake sits. Sorry if my descriptions are hard to understand. Anything will help. This 94 degree weather + Black interior - A/C = An unbearable ride.
    Thanks!
  2. #2 Re: Quick question before i run to autozone.
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    You are low on refrigerant, r-134a. At least have some semblance of a clue of what you are doing if you are going to charge it, though. If this is a 97-03 3.8L Grand Prix, the port by the firewall on the driver's side is the low pressure port. They are different sizes, though, so you can only fit a low pressure line on a low pressure fitting.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Quick question before i run to autozone.
    Feb 2009
    Ada, OH
    Thanks man, I appreciate it. I did some searching lastnight on the procedure. I'm assuming the kits are similar for the most part. Recharge Your AC - How To Recharge Your Air Conditioning With Freon - Warm AC Fix Do It Yourself
    ^That's the website i found with the easiest steps.
    Just a side question, what causes this r132a to leave vehicles? Does it just wear out?
    Thanks again!!
  4. #4 Re: Quick question before i run to autozone.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I'm not a fan of the DIY systems. Refrigerant is usually low because of a leak, so not only will the new refrigerant probably leak out, too, but air and moisture probably got in, so the system really needs evacuated at least, and the drier probably needs replaced. Another issue is now much to add. You don't know how much is in there, so adding more is a total shot in the dark, too much and the system won't work right, either. A single gauge on the low pressure side doesn't even come close to giving you the whole story.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Quick question before i run to autozone.
    Waynesboro, PA
    Quote Originally Posted by Scimmia View Post
    Air and moisture cannot get into the system unless it is empty...otherwise it is still pressurized to some degree.
  6. #6 Re: Quick question before i run to autozone.
    Waynesboro, PA
    Quote Originally Posted by pontiacgp759 View Post
    Thanks again!!
    The only thing I do not like about those instructions is it tells you to turn the can...that can lead you to introduce liquid refrigerant, which is hard on the system. You want to shake the can to get the vaporized refrigerant in. It takes a little longer, but it does not have the risk of slugging the compressor. Shoot for 30-35psi on the low side. Your refrigerant has leaked out, so a can of the stuff with the stop-leak in it could help. As was previously stated, this is not the "best" way of fixing things. However, if you know what you are doing, the vast majority of the time you can pacify the problem and end up with a system that functions like new again for quite some time.
  7. #7 Re: Quick question before i run to autozone.
    NH
    Get a salad bowl of the hottest tap water you have. Stand the can upright in it as you fill the system. It will not be too hot, due to the can cooling as you fill. Put in a bit, and close the valve to check the system pressure again. It usually takes a couple of cans if you're pretty low. It's pretty fool proof if you are careful.
    AND, you don't turn the can. You fill gas into the low side with the can upright. The hot water helps evaporate the liquid R134a, and helps empty the can.
  1. quick question
    Last Post: 06-04-2009, 06:15 PM
  2. Going to 3.4. Quick question.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2009, 01:50 AM
  3. Quick little question
    By TheDesertFox in forum Visual/Body Modifications
    Last Post: 02-13-2009, 12:15 AM
  4. quick 1 HID question
    By wildkyle90 in forum Visual/Body Modifications
    Last Post: 12-14-2008, 04:16 PM
  5. Quick PF question
    By BluFlameGTP in forum General Tech Discussion
    Last Post: 12-09-2008, 01:13 PM
