Thread: Brake Lights - 1991 Jeep Cherokee
Results 1 to 2 of 2
  1. #1 Brake Lights - 1991 Jeep Cherokee
    SE Level Member jprixgt's Avatar
    Jacksonville, FL
    Okay, so I know this forum is about our Grand Prix's...however, I'm working on someone's Jeep Cherokee and have run into a stumbling block. The brake lights will not work. If you turn the lights on, the bulb will turn on as will all of the rest of the lighting. However, if you press the brake, the light does not get brighter. Also, if the lights are off and you press the brake, no light. So here is what I've done so far:
    1. Changed all bulbs in the rear (had to since there was a turn signal issue as well)
    2. Checked all wiring I could see. It appears to be in order, checked against service and repair manual. My theory also is if there was a wiring problem or short that the light would not work period.
    3. Checked all fuses. All are good. Again, if there was a bad fuse, I assume the light would not work period.
    Soooo....here's what I'm thinking now: Is it possibly the brake light switch and plunger assembly located with brake pedal. It's the only thing I can think of at this point. If that's a possibility, is there a way to test the existing switch?
    Does anyone else have any other thoughts on what the problem could be?
  2. #2 Re: Brake Lights - 1991 Jeep Cherokee
    GTP Level Member SuperSport's Avatar
    Michigan
    Yep. Im familiar with that beast. Check the switch on top of the brake pedal. My lights were out one day a few years back on my Cherokee and the wire going to the switch was broken. That may be your case, or simply a bad switch.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  1. 1991 grand prix od?
    By thenervemann in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-13-2009, 02:25 PM
  2. My 2008 GXP HAS NO BRAKE LIGHTS
    By tas1977 in forum Brakes/Suspension/Chassis
    Last Post: 01-25-2009, 03:20 AM
  3. Any Suggestions on brake lights
    By Hamm61 in forum General Tech Discussion
    Last Post: 09-29-2008, 06:50 AM
