Thread: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
Results 1 to 20 of 24
  1. #1 Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    SE Level Member alilsassygrl's Avatar
    sacramento, ca
    any help/input will be so awesome! Im stumped...My 03 grand prix 3.1 SE 96,000 miles~~ ran out of gas a week ago. Put gas in no start.
    No sound heard at fuel pump.
    Replaced fuel pump relay today, fuel filter and fuel pressure regulator. Still no start no sound at pump.
    Strange (not loud) grinding type noises comming from EGR valve or 1 of the tubes in that area??? This grinding sound occurs when I turn the key off and/or when I remove the ignition fuse main, the sound will start up when I pull the fuse out and when I replace/put the fuse back in??? So strange. Im stumped and ready to buy a fuel pump but just want to be sure as others have told me to check ignition area first.
    PLEASE HELP W/ ANY IDEAS! I just dont know and dont have the money to keep guessing, lol...=)
    UPDATE~ When I unplug this red/blue plug the noise dissapears. I think it may be part of the map sensor wiring harness?? This plug leads to a series of other plugs through black tube. Does the whole harness need to be replaced?
    Thank u!! for any input/ideas =)
  2. #2 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    TDCRacing
    Guest
    First you need to figure out why the fuel pump is not comming on. Becaus that is your main and more than likley only problem.
    Being that you replaced the relay already I would have to say that you may need a new pump. If you need to know how to change it you can follow this post that I made on how to do so.
    http://www.grandprixforums.net/f73/f...all-11155.html
    Also if you need a low milage pump Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts has one. Ask to speak with Eric and tell him Parker From TDCRacing sent you.
    That should do the trick if not let us know.
  3. #3 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    i know your so right I need the fuel pump. I will call thank you so much! I foung one on ebay for $99 but Im afraid to buy it their... Im an ebay powerseller but just seems scary buying car parts on ebay.
    Anyways thanks for setting me straight, The pump should be working and would not be quiet due to a clogged AIE VALVE, correct?
  4. #4 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    IAC valve~~ sorry,lol..
  5. #5 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    By the way that post w/ the pics AMAZEING! Guy told me he had to drop the tank, but because of yours and other posts I knew better!
    Very helpful...
  6. #6 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    TDCRacing
    Guest
    Yeah. Don't buy that pump off of ebay. I'm sure they could gie you a much better deal than that. And no the IAC valve would not cause to car to not run or the fuel pump not come on.
  7. #7 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    ok ill try calling now, hope they are open. All I can say is thank you so much! Those pics make me so confident, i can do this. =) I love working on cars, its just about having all the right tools. Oh and knowing whats wrong, lol...
  8. #8 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    wow they are actually ebay powerseller too....
  9. #9 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    TDCRacing
    Guest
    Got a link to your store?
    No problem about the help lol
  10. #10 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    so to bother again, will u check this link and tell me if you think I should buy it. Its from the company you said to call.
    Thanks
    Monte Carlo Impala Grand Prix Century Fuel Pump:eBay Motors (item 390056618106 end time Jul-01-09 14:17:23 PDT)
  11. #11 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    TDCRacing
    Guest
    PM sent.
  12. #12 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    yes my newest one, my older one is closed and on vacation mode, I sell antiques on that one. This one has nothing listed because I just got back from a 2 week camping trip and also its all womens fashion in this one
    http://my.ebay.com/ws/eBayISAPI.dll?...e=STRK:ME:LNLK
  13. #13 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    TDCRacing
    Guest
    Quote Originally Posted by alilsassygrl View Post
    And I would be out of luck.
  14. #14 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    whats pm sent? =0
  15. #15 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    TDCRacing
    Guest
    whats pm sent? =0
    Actually check your email. I think you have private messaging disabled. Because it would not let me send you one. It would only let me send you an email.
    PM = Private message.
  16. #16 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    Geeeer, Im good w/ cars but sure cant figure this site out, lol... I ll try to fix it, lol... Did you check that listing, its used but from the company you spoke of...
  17. #17 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    TDCRacing
    Guest
    User CP then select edit options on the left hand side. Then select enable private messaging. I sent you an email regarding that link to the companay I recomended. So check your email. Like yahoo or who ever you have and it should be in your inbox.
  18. #18 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    seems fine, says private message inbox 0.......?
  19. #19 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    sacramento, ca
    nothing in my aol. email... wa9hei@aol.com, nothing there, strange. k ill try that
  20. #20 Re: Ran out of gas no start gurgeling noise from egr area???HELP! PLEASE
    TDCRacing
    Guest
    You have to enable it to be able to receive them though
  1. PA Area
    By rocafella2032 in forum Northeast
    Last Post: 10-30-2017, 08:34 PM
  2. CT area.
    By prixgt04 in forum Northeast
    Last Post: 12-21-2011, 01:46 PM
  3. pittsburgh area
    By Brettgtx02 in forum Northeast
    Last Post: 07-07-2010, 04:01 PM
  4. Anyone in the pittsburgh area...
    By the1euge in forum Northeast
    Last Post: 08-07-2008, 01:24 PM
  5. Pictures area
    By archemedes in forum Forum Bugs/Suggestions
    Last Post: 02-18-2008, 05:20 PM
