Thread: Evaporator Control Valve
Results 1 to 6 of 6
  1. #1 Evaporator Control Valve
    Mississauga
    Hi,
    Today I took my 2004 grand prix in to the dealer. They hooked it up to the computer and told me that I had to have the Evaporator Control Valve replaced.
    They charged me $130 for using the computer and want to charge me $340 to replace the valve. On top of that they also made me pay for $170 throttle body service before they would even look at the problem.
    Does anyone think I'm getting riped off here?
    I called a local mechanic and he told me the Valve is only around $50.
    What really upsets me is why this isn't covered under my extended warranty. Such a part should be covered since there appears to be so much labor involved. How could such a job fall under normal maintenance on the vehicle?
    At this point, I'm about to tell them that they should just disconnect the sensor so it stays open. Why should I pay them that much money for something I don't need?
  2. #2 Re: Evaporator Control Valve
    Don't pay them a nickel. You didn't even want your throttle body cleaned, you could have done it yourself. Buy the part from the parts dept. for $50 or whatever and install it yourself. Then with the $400+ saved...go buy some nice chit for your car
  3. #3 Re: Evaporator Control Valve
    Mississauga
    well I asked them to disable the sensor, but the lady told me they won't disable anything.
    I guess I will have to figure out how to do that myself.
    You are correct, I think will just install it myself. How long can it take anyway? $280 for labor is crazy.
  4. #4 Re: Evaporator Control Valve
    Sorry...I'm mainly a '97-'03 L67 person...if the Evaporator Control Valve is the same thing as the EVAP on our cars...then MAYBE 5-10 minutes if you have never done it before...
  5. #5 Re: Evaporator Control Valve
    Mtn. View MO
    where is the evap in a 98 supercharged located, i need to replace mine and i have no idea where its at
  6. #6 Re: Evaporator Control Valve
    Joliet, IL
    fukkin delete that shyt....i have no egr or evap they are needless....just get the codes turned off with a powertuner.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  1. EGR valve
    By cobra8432 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2011, 11:12 PM
  2. EGR Valve! What does it do?
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2009, 09:40 PM
  3. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  4. EGR Valve?
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:24 PM
