Thread: GT Body Side Molding
Results 1 to 3 of 3
  1. #1 GT Body Side Molding
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    I have an '01 GT and it has that wide body side molding that runs along the bottom of the doors. The piece on the driver's door is starting to come off at the trailing edge. I looked at it quick and it looks like it attaches with some sort of clip system, but I can't tell if the clip just popped out of position or is actually broken. I don't want to just pry at it without knowing how it comes off.
    Anybody know how that trim piece attaches or comes off?
  2. #2 Re: GT Body Side Molding
    SE Level Member davidl25's Avatar
    Apr 2009
    evansville in.
    they have clips that clip into the door. They have most likely broke. You can pry it off but try not to bend the molding or it will crease in it. Then go buy new clips and snap it back on.
    99 GP (SE) GT Clone, KYB AGX struts + SSC springs, GMPP sway bars, GMPP trailing arms, OTTO strut tower brace,Big 3 mod, Stage 2 voltage booster, alt rewire, 180 t stat, HID conversion, D/S rotos and ceramic pads,cold air intake, and an insane car audio setup 150+ db.
  3. #3 Re: GT Body Side Molding
    Dec 2008
    ****'s Creek
    Thanks for the info
  1. side molding removal
    By 01RedfireGT in forum Visual/Body Modifications
    Last Post: 05-15-2009, 01:43 AM
  2. Side mirror on driver's side
    By jokyfo in forum Shops and Community Heroes
    Last Post: 04-29-2009, 03:50 PM
  3. Molding and trim fasteners
    By jokyfo in forum General Tech Discussion
    Last Post: 04-02-2009, 09:23 AM
  4. Side molding removed pics?
    By copgtp in forum Visual/Body Modifications
    Last Post: 11-02-2008, 08:09 PM
  5. Passenger door lower molding
    By dwm1975 in forum General Tech Discussion
    Last Post: 08-13-2008, 05:04 PM
