Thread: SC Nose drive change or pulley change
Results 1 to 4 of 4
  1. #1 SC Nose drive change or pulley change
    SE Level Member jamster00's Avatar
    Apr 2009
    san diego
    Hi all,
    I'm a bit confused of this mod. Hope you guys could clear this up for me. What is the best procedure for doing this mod? I've read online that any pulley puller is not going to work and cause damage to the SC. I've seen videos and seem to be easy to pull off the pulley that was pressed on by a 10ton machine.
    Would like to hear anyone who used a pulley puller successfully or not.
    thanks,
    Jamster00
  2. #2 Re: SC Nose drive change or pulley change
    Do you have supporting mods for the pulley you are putting on? If not then I would say don't even change the pulley yet. A smaller pulley doesn't always mean a faster car. As for the puller they work great. You just either have to rent one or fork out the cash for one...and it has to be the special pulley puller tool...not a typical one you can rent from your auto parts store...they can get the pulley off but it either ends up damaging the snout, the pulley you take off, or the tool.
  3. #3 Re: SC Nose drive change or pulley change
    Apr 2009
    san diego
    So far I've installed an SLP CAI, 180tstat, custom catback exhaust. I'm now looking into a PCM and eyeing on a 3.5 or 3.4" pulley. Which pulley are you referring to? Was it a simple task?
    thanks,
    Jamster00
  4. #4 Re: SC Nose drive change or pulley change
    Don't. You don't have enough flow mods to drop a pulley size.
  1. anyone ever change a gt to a gtp
    By e56505 in forum General Tech Discussion
    Last Post: 02-18-2009, 12:12 AM
  2. How soon do you change the oil after........
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2009, 03:56 PM
  3. pulley change
    By ROTTMAN in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2009, 09:13 PM
  4. Possible to change drive/driven sprockets in-car?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2008, 03:18 PM
