Thread: Sticky Throttle
Results 1 to 7 of 7
  1. #1 Sticky Throttle
    Cleveland, Ohio
    Hey i have a 2000 grand prix gt 3800, 147,000 miles. sometimes after my car warms up, the throttle will stick open. now i am not sure if its the IAC or if its the TPS that have either gone bad or need a cleaning. if someone has any info on this issue that would be greatly appreciated.
  2. #2 Re: Sticky Throttle
    TDCRacing
    Guest
    If it's the actual throttle sticking then more than likley you need to clean all of the carbon and black stuff that is in the throttle body.
    If it's the IAC then do the same and make sure you get the IAC passages real good.
    You can clean all of the above with Carb cleaner or something of that nature.
  3. #3 Re: Sticky Throttle
    Cleveland, Ohio
    sounds good boss, thats what i figured. i hope that its not the actual cable.
  4. #4 Re: Sticky Throttle
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    Quote Originally Posted by incubus6930 View Post
    Spray the cable and linkage while your at it!
  5. #5 Re: Sticky Throttle
    Quote Originally Posted by WhiteGT View Post
    Spray the whole motor too!!
    If that doesn't work then try swapping IAC's with someone...that will always tell you whats up
  6. #6 Re: Sticky Throttle
    Arnprior, Ontario
    it isnt the IAC, i am havig that issue and i have put a new IAC and TPS on my 1999 grand prix GT 3800 series 2, and i have cleaned the throttle body but apparently not well enough as mine is still sticking sometimes.
  7. #7 Re: Sticky Throttle
    Please open a new thread.
    Thanks.
  1. sticky brakes
    By r70chevy in forum Brakes/Suspension/Chassis
    Last Post: 05-06-2009, 01:33 PM
  2. sticky gas pedal
    By johnnyj773 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-22-2009, 05:00 PM
  3. Sticky Needed for the NA 3800 Section(L26/L36)
    By 02BlueGT in forum Forum Bugs/Suggestions
    Last Post: 11-26-2008, 03:21 AM
  4. Tire Section needs a sticky
    By 03GPScottyd in forum Forum Bugs/Suggestions
    Last Post: 07-10-2008, 12:36 PM
