Thread: check engine light goes on and off!!
Results 1 to 15 of 15
  1. #1 check engine light goes on and off!!
    roselle
    i brought it to autozone and the scanner said bang 1 running lean so i put a new o2 senser in and did spark plugs and wires and it still comes on when it wants to so i brought it back to autozone after i did the parts and it still says the same think im going nuts please help its a 2000 gt thanks
  2. #2 Re: check engine light goes on and off!!
    TDCRacing
    Guest
    You have a vacume leak somewhere.
    Check all of your vacume lines to start with. If you still can't fins anything then it may be an intake gasket
    Let us know.
  3. #3 Re: check engine light goes on and off!!
    roselle
    ok i will check and let you know how it goes thanks
  4. #4 Re: check engine light goes on and off!!
    roselle
    i have no vacum leaks what is the best way to check the intake if its leaking?
  5. #5 Re: check engine light goes on and off!!
    TDCRacing
    Guest
    Carb cleaner while the engine is running. You have a vacume leak. It's just hard to find. It could be a slight crack in a hose that you can barley see. But you have one. Also check the evap silinoid. It's the one by the firewall with 2 cases and connectors running to it. Check it where the hoses connect to the silinoid. Sometimes the clips break and the hose looks like it is on there but it's not.
    When you spray the carb cleaner on all of the hoses and you hear a raise in the idle you have your leak.
  6. #6 Re: check engine light goes on and off!!
    roselle
    ok testing it in a little bit will let you know how it goes thanks again
  7. #7 Re: check engine light goes on and off!!
    roselle
    i used the carb cleaner almost a hole can motor did not rev up at anytime
  8. #8 Re: check engine light goes on and off!!
    roselle
    i cant find the one on the fire wall
  9. #9 Re: check engine light goes on and off!!
    roselle
    im going nuts i cant figure it out!
  10. #10 Re: check engine light goes on and off!!
    TDCRacing
    Guest
    Did you check all of the vacume line for cracking ect?
  11. #11 Re: check engine light goes on and off!!
    Check that damn T-Fitting vacuum line. It runs from the fuel rail under the Upper Manifold to the side of the Lower Manifold and back to EVAP Canister...try those...they are always the first things to go...dry rot FTL.
  12. #12 Re: check engine light goes on and off!!
    GT Level Member pontiackid's Avatar
    KCMO
    Do you have acces to a tuner or scanner. When I had mine the only way we could find it was be using carb cleaner. When you find it your STFT will go to zero for a second... also could be a bad MAF sensor. Try cleaning it.
  13. #13 Re: check engine light goes on and off!!
    roselle
    i found what it was guys it was t-fitting vac line thanks for all your help
  14. #14 Re: check engine light goes on and off!!
    Quote Originally Posted by stanggreg90 View Post
    HA!! Did I call that or what?
  15. #15 Re: check engine light goes on and off!!
    Nov 2008
    Chicago
    mine's been going on and off as well due to a vacuum leak (bad IC gaskets).
  1. Check Engine Light
    By Alpha388th in forum General Tech Discussion
    Last Post: 02-20-2009, 11:48 PM
  2. check engine light
    By kiljoy06 in forum General Tech Discussion
    Last Post: 01-11-2009, 07:27 AM
  3. check engine light
    By keenan00gtp in forum General Tech Discussion
    Last Post: 12-01-2008, 10:25 PM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Check engine light on
    By darkwingduck in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-18-2008, 07:59 PM
