Thread: Help key won't come out
Results 1 to 3 of 3
  1. #1 Help key won't come out
    GT Level Member Davisgtp's Avatar
    Dec 2008
    Rockford, Illinois, United States
    What can cause the key to get stuck in the ignition
    Thrasher Intake, Intense 3.4 pully with other mods, DHP PCM, u bend delete, 20" Kmc Wheels with Nitto Neo Gen Tires
  2. #2 Re: Help key won't come out
    Banned - Busted For Scamming
    Feb 2009
    bad solenoid in the steering column.
  3. #3 Re: Help key won't come out
    tj
    Quote Originally Posted by Davisgtp View Post
    take off that solenoid , trashed mine .. everytime i turned off the ignition switch i could not take off the key , theres a little hole under your steering column if you stick a screwdriver or something thin in it , you could take off your key , but it will start failing on you once it starts sticking so i dump it .
key
