Thread: clicking sound under dash
Results 1 to 11 of 11
  1. #1 clicking sound under dash
    Willoughby, Ohio
    whenever i turn on my heat/AC/or just cool air, there is a clicking sound comming from under the passenger side dash board...it sounds like a fan rubbing against something but air still flows thru the vents...it doesnt matter wut temp or which vents r blowing the air, the clicking is ALWAYS there when i have the fan on...wut is this and is it hard to fix???
  2. #2 Re: clicking sound under dash
    Nov 2008
    Chicago
    your fan might be dirty. does it vary with the speed of the fan?
  3. #3 Re: clicking sound under dash
    Willoughby, Ohio
    ya 1 2 and sometimes 3 make the noise not 4 n 5... i took it out n cleaned it...still makes sound
  4. #4 Re: clicking sound under dash
    Oct 2008
    mascoutah, Il
    http://www.grandprixforums.net/f95/c...ash-15395.html
    Was the fan damaged, have rub marks or wobble?
    2002 GTP
    custom HOK paint
  5. #5 Re: clicking sound under dash
    Nov 2008
    Chicago
    take the fan apart and see where its rubbing. If you can't figure out the cause of the problem and you dont want to buy a new fan, you could file down the plastic where its rubbing. If you decide to go this route, only take off what is needed. I'd recommend using a metal file or a dremel tool.
  6. #6 Re: clicking sound under dash
    Willoughby, Ohio
    it doesnt make the sound when i spin it in my hands which leave me to believe its rubbing (but shows no marks) or the actual motor is bad
  7. #7 Re: clicking sound under dash
    Ocoee, Florida
    Can you change the air temp from the vents, meaning hot air then cold air. When the blend door actuator goes bad, it often has a clicking noise coming from it, Skip
  8. #8 Re: clicking sound under dash
    Willoughby, Ohio
    ya eerything works fine, temp...fan speeds... it just clicks like its hitting something or the motor is clicking
  9. #9 Re: clicking sound under dash
    Oct 2008
    Northern Illinois
    This same noise was happening on mine for a couple weeks...now it doesnt work at all
  10. #10 Re: clicking sound under dash
    Willoughby, Ohio
    hmm thats weird its so annoying!
  11. #11 Re: clicking sound under dash
    Oct 2008
    Northern Illinois
    Quote Originally Posted by CTKGP09 View Post
    If you figure it out let me know cuz I was hearing the same noise right before the blower stopped working.
  1. how to get more sound out of s/c?
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 01:31 PM
  2. S/C Sound
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 11-18-2008, 10:33 PM
  3. what should i do to get this sound?
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2008, 07:22 PM
  4. Squeaking/clicking in dash, climate control?
    By jagamite in forum General Tech Discussion
    Last Post: 10-21-2008, 11:05 PM
  5. How does this sound?.....
    By wrfdff4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2008, 06:53 AM
