Thread: Please help...P1629
Results 1 to 4 of 4
jessie9284 Please help...P1629 06-11-2009, 03:29 PM
minichopper6hp Re: Please help...P1629 06-11-2009, 04:29 PM
dstout Re: Please help...P1629 06-11-2009, 09:30 PM
bbptech Re: Please help...P1629 06-12-2009, 04:43 AM
  1. #1 Please help...P1629
    North Carolina
    I have a 2000 Grand Prix SE. Last yr it would randomly start, but then shut off after 5 seconds. It always resolved itself within a day or so. The check engine light was on, so I had it scanned and it came up as the crankshaft position sensor. My brother works on cars and was going to replace the part, but was having a hard time reaching it without disassembling many things, so we decided since it was running ok after leaving it overnight, we would just let it go.
    Now a yr later, after no problems recently, it did it again. This time even after leaving it alone, it won't start. I had it towed and they said they pulled up code 1629, which is related to the anti-theft system and it would be 10 days and $500 to fix it. I am second guessing them because my security light has never stayed on, or blinked. It comes on with the other lights as I start the car, so I know its not burned out. I did some research about the code and found it could be related to the crankshaft sensor. They are pretty adamant that its the anti-theft system though. Is it possible to have this problem and this code be related to the anti-theft module with no security light being involved? Could this code be related to the crankshaft sensor? Would it behave this way if that were the problem? Please, any advice would be greatly appreciated...I am a struggling single mom and don't want to replace something for $500 if I don't have to. Thanks.
  2. #2 Re: Please help...P1629
    Banned - Busted For Scamming
    Feb 2009
    are you using a copy of a key?
    sounds like it could be a transistor/key issue.
  3. #3 Re: Please help...P1629
    GTP Level Member dstout's Avatar
    ky
    I had a remote starter on mine and after a while the TDM = Theft Deterent Module would burn out and when that happened it would shut down the fuel pump.....the car would start and then die after a few seconds.
    If you have a remote start that might be what is causing your problem, I don't remember what the codes were.
  4. #4 Re: Please help...P1629
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Mine has done this as well. Only creaper, the car has started by itself twice at 3 and 4 in the morning. And that was while the engine hoist was holding the motor in the air with no front manifold. But the other day i hit the start button on my auto start and it did the same thing. It through the P1629 code so i read up on it. Heres the link to help u and understand what the problem is. hope this helps. Oh and i realize it says 2001 Chevrolet/Geo Camaro at the top but it is basically the same exact code.
    DTC P1629
