Thread: mysterious connector!?
Results 1 to 14 of 14
  1. #1 mysterious connector!?
    Donating Users
    Plainfield, IL
    i found this connector in my fender on the pass side...i looked on the driver side but didnt find one....anybody know what this is? what is it for? there are connectors on the hump where the strut is behind the battery that look the same but are already connected....where does this connect? i have no codes...its just two black wires going into a connector....
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: mysterious connector!?
    Donating Users
    Plainfield, IL
    BUMP! what is this guys someone has to know...
  3. #3 Re: mysterious connector!?
    Barksdale AFB, LA
    Well, it looks like the coolant temp sensor harness connector, but that's over on the engine. No idea what it would be over there. The only things in that area I can think of are the horn and windshield washer fluid reservoir/pump.
    2009 Subaru Impreza WRX STI
  4. #4 Re: mysterious connector!?
    Donating Users
    Plainfield, IL
    windshield wiper fluid works it told me i was low recently...horn works oh well if everything is working i guess fukkk itt
  5. #5 Re: mysterious connector!?
    Jersey
    i have that same plug, i noticed it when i removed the battery. Mine is plugged in and has 2 wire going into the fuse box
    16' wrx sti- stock
  6. #6 Re: mysterious connector!?
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    Somebody correct me if I am wrong, but isnt that the Fuel Pump resistor? It doesn't make sense that it would be unplugged or not jumped around.
  7. #7 Re: mysterious connector!?
    Donating Users
    Plainfield, IL
    maybe my car has a caspers fuel pump rewire when i bought it and my Fuel pump resistor is bypassed?
  8. #8 Re: mysterious connector!?
    Barksdale AFB, LA
    Impalas or Montes don't have that, so maybe that's why I didn't recognize it.
  9. #9 Re: mysterious connector!?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    That is the other end of the harness for the outside air temp
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  10. #10 Re: mysterious connector!?
    Donating Users
    Plainfield, IL
    so where can i find where it plugs into?
  11. #11 Re: mysterious connector!?
    probably down in ur fender!
  12. #12 Re: mysterious connector!?
    Aug 2011
    louisiana
    i found a plug that looks like the male end of that when i changed my battery .. i was underneath my battery so idk. ive been searching for where the hell it plugs in lol
  13. #13 Re: mysterious connector!?
    It doesn't. Check a couple more threads. Someone identified what it shoudl be for. It's optional .
  14. #14 Re: mysterious connector!?
    St. Louis
    It's for this. Some of the GTP SE GTX Daytona models had it, but only 1 and 1/3 of them. The rest were stock with only the Nascar engine as standard.
