Thread: SES Light....Suggestions
Results 1 to 20 of 21
  1. #1 SES Light....Suggestions
    SE Level Member bloxmagic's Avatar
    Oct 2008
    Carmel
    So today i was on my way home and my SES light came on for no apparent reason. So i pulled over just to check and make sure everything was OK. Anyone have any ideas on what it could be... the light is on solid, i just did a tune up about 3 weeks ago and everything has been fine, it is a 2000 GP GT and it has about 48,000 miles on it and just did an oil change at 46,000.... any help you be greatly appreciated. My take might be the 02 sensor is going bad but then i have 19mpg so i am not sure....
    '00 Fire Engine Red GT Sedan - PCM Tuned, 180* T-Stat, FWI, 70mm Throttle Body Adapted, MSD Coil Packs, MSD Ignition Wires, AL 605 Plugs, Coated Headers (New Headers Soon), 145 amp high output alternator, 2 12" Kenwood Subs, Alpine PDX1.1000 , Alpine Type R Speakers, Alpine HeadUnit
  2. #2 Re: SES Light....Suggestions
    GT Level Member chad27's Avatar
    Apr 2009
    gpt,ms
    go to auto zone for a free scan
    1.0 pcm upgrade, comp cam, zex 50 shot, msd 8.5mm wires, copper plugs side gap, head work comp springs, all fluids mobile one
  3. #3 Re: SES Light....Suggestions
    Oct 2008
    Carmel
    oh alright thanks did not know about that well i will post up what they tell me
  4. #4 Re: SES Light....Suggestions
    TDCRacing
    Guest
    Yep post it up. We will be glad to help. There are 1000's of codes. So it would be kind of hard to guess.
  5. #5 Re: SES Light....Suggestions
    Oct 2008
    Carmel
    so i went to autozone and got the code and then i wrote it down then lost it somehow but the code was talking about how the coolant temp was not the same as the thermostat temp so i bought a new temp sensor and am going to install it... if anyone has any other ideas let me know
  6. #6 Re: SES Light....Suggestions
    Apr 2009
    gpt,ms
    well that could have been it. just wait to see if it comes back on.
  7. #7 Re: SES Light....Suggestions
    Oct 2008
    Carmel
    ok now i got the code P0128 coolant temp below thermostat regulating temp... so i replaced the thermostat and how do i reset the ses light?
  8. #8 Re: SES Light....Suggestions
    Apr 2009
    gpt,ms
    you will need the scan tool they will reset it sometimes at auto zone just depends tell them you replaced the part
  9. #9 Re: SES Light....Suggestions
    Becca Boo MizzBecca's Avatar
    Michigan
    dont be suprised if it comes on again, on my 94 it comes on if i go over 60 then slow down n press the break. nothing comes up on the scan, but mine is like 15 years old lol
    I drive a POS
  10. #10 Re: SES Light....Suggestions
    Oct 2008
    Carmel
    yea i replaced the thermostat but now i had trouble replacing the ECT sensor and was not able to do it.... does anyone have any suggestions on how this should be done? Thanks!
  11. #11 Re: SES Light....Suggestions
    GTP Level Member dstout's Avatar
    ky
    You can disconnect the battery and let it sit for a while and it should clear the code.
  12. #12 Re: SES Light....Suggestions
    Oct 2008
    Carmel
    well i cleared the code thanks for the help only time will tell if i get the code back.. thanks again!!!
  13. #13 Re: SES Light....Suggestions
    Apr 2009
    gpt,ms
    battery never worked for me
  14. #14 Re: SES Light....Suggestions
    ky
    how did you clear the code?
  15. #15 Re: SES Light....Suggestions
    Oct 2008
    Carmel
    well i un did the ecm fuse and un plugged the battery terminals then i let it sit for a while and either that did it or i fixed the problem and the code just went away i have no idea
  16. #16 Re: SES Light....Suggestions
    ky
    Good job just keep watching it, it may or may not return.
  17. #17 Re: SES Light....Suggestions
    Oct 2008
    Carmel
    alright yea thanks for the info!
  18. #18 Re: SES Light....Suggestions
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    I noticed in your sig that you have a 180* t-stat, if you don't have the PCM tuned for it - you will continue to get P0128 codes (depending on weather - especially when colder). Just FYI.
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  19. #19 Re: SES Light....Suggestions
    TDCRacing
    Guest
    IT's weird. I've heard of this happening. Only heard. Never got to meet anyone it actually happend to. But I ran a 160 for about a year. Through summer and winter and this never happend to me.
    If it's saying the thermostat was a different temp the inside gauge then it's a bad thermostat. But in realits there is no way the PCM even know's what temp the gauge is at inside. It operates off of the Sensor it self
  20. #20 Re: SES Light....Suggestions
    Oct 2008
    Carmel
    yea it was a weird code i could not figure it out but i just went ahead and replaced the thermostat and reset the code and its been fine
  1. '06 gxp mod suggestions
    By Cableguy in forum 5.3L V8 (LS4)
    Last Post: 10-13-2009, 07:04 AM
  2. suggestions on fix, please?
    By killbill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-03-2009, 07:38 AM
  3. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  4. Help me out. Suggestions??
    By keenan00gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2008, 08:14 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
