I purchased an 01 ssei engine to go into my 97 gt and I found out the wiring harness are completely different (I should have known). How hard is it to convert the wiring so it will work and what is involved? Thanks
buy the pcm for that same engine and buy the harness for that make also.. and you should be good? i'd think.. we'll see what everyone else says here. i'm actually going to consider doing the same thing.
why do you need to switch the wiring harnesses if all youre using is the motor? just use the GT stuff and it will work fine unless youre looking for a plug and play solution, which would be to get the PCM from that motor too.
Just track down a '97 GTP Motor and transmission with the PCM.![]()
The easiest solution would be tto send your pcm to ZZP and have them tune it for a top swapped setup .
Well there are MANY capable people around the Kansas City area. I know, I live there. If he gets a NON-97 Motor and Trans then he will not have to worry about the vacuum powered '97 transmission...and then if he got the PCM from that motor/tranny setup it would be like tuning a '98-'02 GTP. Easy. Plus no one at ZZP has any credible tuning skills as of now and they having nothing but Cobalts to back it up now. Sure maybe a few years ago when they had their 8 second turbo car out the track all the time, but not anymore. But enough about ZZP.
selliott, go jump on a local club and get to know a few of us. Kansas City Pontiac Motorsports Club - Home Reptile and Abrasive on here have done MANY projects on the 3800 series engine and Reptile does great tuning, especially since he has a HP Tuners, but also knows the in's and out's of the DHP Powertuner (which has tuned mine many a times). Hope you get it figured out and if you do, shoot me a question if you'd like and I can be sure to try and help you out since your in the KC area![]()
