Thread: short fuel trim
Results 1 to 20 of 22
  1. #1 short fuel trim
    Donating Users
    Plainfield, IL
    i dont understand what fuel trims are and how to diagnose them through my aeroforce when does it change and why where should it be at idle and wot? i need some insight on fuel trims so i know what i should be seeing because im throwing code P0133 and i read that its due to a slow response occuring with short fuel trim....lemmme know
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: short fuel trim
    Outer Space
    Dont worry about STFT's .... LTFT's is what you need to watch... a + value means your running lean and the PCM is adding fuel. - Values mean your running rich and fuel is being removed.
    Get ahold of a tuner and do some MAF tuning to correct these values. You want to be in the +3 or -3 range for LTFT's.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: short fuel trim
    ^^ what he said. youll never get STFT to stay around zero...ever.
  4. #4 Re: short fuel trim
    Donating Users
    Plainfield, IL
    well at idle my ltft's are +16 an at wot im around -3 is that good or am i runninglean hence the headers and no tune?
  5. #5 Re: short fuel trim
    Outer Space
    Quote Originally Posted by gotboost3 View Post
    +16 ltft's is most like a vac leak.
  6. #6 Re: short fuel trim
    Barksdale AFB, LA
    Well, it's pulling fuel for some reason at WOT which is not good. Also, the LTFT at +16 indicated a vac leak. Do you have your rear O2 removed by any chance?
    2009 Subaru Impreza WRX STI
  7. #7 Re: short fuel trim
    TDCRacing
    Guest
    You want your trims at WOT and PT to be at 0. The only way to get them there is with an AFC or a MAF tune. NOT a PCM.
  8. #8 Re: short fuel trim
    Donating Users
    Plainfield, IL
    yeah im catless no rear o2
  9. #9 Re: short fuel trim
    Donating Users
    Plainfield, IL
    wouldnt i be able to notice a vacuum leak on my boost gauge? my vacuum sits at 20 all day and driving its at 10 then at wot im at 6.5 psi....sounds right there are some ripped vacuum fitting on my tb and FPR tho maybe those are it....
  10. #10 Re: short fuel trim
    will you tune your car already. all those mods you threw at it have everything thrown off on your PCM.
    besides, +16.4 at idle is usually a vacuum leak. 9 times out of 10.
  11. #11 Re: short fuel trim
    Donating Users
    Plainfield, IL
    thats exactly what i get at idle it stays at 16.4 never moves till i give it throttle or the cars moving...
  12. #12 Re: short fuel trim
    Donating Users
    Plainfield, IL
    i have no money haha i want a tune trust me...i think im leaking from the vac tube on the TB...would that cause this?
  13. #13 Re: short fuel trim
    Donating Users
    Plainfield, IL
    im hardly getting any kr thats good at least with no tune for now right i see at most 1.2 kr
  14. #14 Re: short fuel trim
  15. #15 Re: short fuel trim
    Donating Users
    Plainfield, IL
    damn i looked for a vacuum leak but i cant find one....got some loose fittings that i guesss could be leaking....could a bad canister purge solenoid cause this?
  16. #16 Re: short fuel trim
    Canada
    Hey buddy wounder if u can help me got a problem that comes n goes got tune pcm at idle im running good once im at cruise im all over the place like +20 to + 35 but when i step on it everything is working perfect as i look at the scanner - disconnected maf works good for a few minutes then everthing goes to hell readings all over the place.Need help
  17. #17 Re: short fuel trim
    GT Level Member DOUGLASMELTER's Avatar
    Apr 2009
    ERIE
    two places to look for a leak when you cant find one externally is the egr valve or the idle air control valve nine times out of ten its the idle air control
  18. #18 Re: short fuel trim
    Apr 2009
    ERIE
    one thing you can try thats quick is to tap on the area around the idle air control valve with a hammer. if the idle inpromves then the valve isnt seating right but failure to notice a change doesnt mean the valve is good either
  19. #19 Re: short fuel trim
    Canada
    The code thats showing is p1133 and the fuel trim is maxing out at cruise O2 sensor was replaced 3 times maf sensor is ok checked it with it pluged and unpluged so basicly at idle its good at exceleration its good only at cruise everything goes to hell...
  20. #20 Re: short fuel trim
    Jul 2008
    Germantown, Maryland
    Quote Originally Posted by silverbulletgtp@msn.com View Post
    plugged, unplugged, acceleration
    Curious... on my HPTuners when I run a scan for the VE can I go by those LTFTs to see whether I have a leak?
  1. 67 trim swap on a Cartuning kit
    By Overkill in forum Turbo
    Last Post: 03-12-2012, 09:29 AM
  2. Molding and trim fasteners
    By jokyfo in forum General Tech Discussion
    Last Post: 04-02-2009, 09:23 AM
  3. door trim
    By evilpacker in forum Visual/Body Modifications
    Last Post: 07-29-2008, 03:12 PM
  4. window switch trim
    By kingd44 in forum The Rant Forum
    Last Post: 03-23-2008, 08:38 PM
  5. Fuel Trim trouble
    By GTP Mike in forum PCM Tuning
    Last Post: 01-21-2008, 08:32 PM
