Thread: Car wont idle help!!!!!!!!
Results 1 to 5 of 5
GINOSGTP Car wont idle help!!!!!!!! 05-06-2009, 11:17 AM
Bio248 Re: Car wont idle help!!!!!!!! 05-06-2009, 12:51 PM
dstout Re: Car wont idle help!!!!!!!! 05-06-2009, 04:50 PM
blueguy Re: Car wont idle help!!!!!!!! 05-09-2009, 02:31 AM
GINOSGTP Re: Car wont idle help!!!!!!!! 05-10-2009, 06:30 AM
  1. #1 Car wont idle help!!!!!!!!
    SE Level Member GINOSGTP's Avatar
    Feb 2009
    Ontario Canada
    I just installed a stage 3 intercooler kit, 8.8mm wires, 104's drilled 160 t-stat, fuel pump re-wire.....i get all excited about the car and for the past three days a cant get the car to idle!!!! I get p0300(random missfire) as a code! I have tried changing plugs wires checked vacuum lines....I'm out of ideas so can anyone help with this problem?????
  2. #2 Re: Car wont idle help!!!!!!!!
  3. #3 Re: Car wont idle help!!!!!!!!
    GTP Level Member dstout's Avatar
    ky
    Does it start run for a couple of seconds then die or will it even start and run? could be the fuel pump shutting down.
  4. #4 Re: Car wont idle help!!!!!!!!
    I thought that the P0300 was a camshaft related issue?
  5. #5 Re: Car wont idle help!!!!!!!!
    Feb 2009
    Ontario Canada
    Pronlem fixed......ihad a bad fuel pressure regulator.....thank you guys for all the help
  1. idle issues
    By gnjim in forum General Tech Discussion
    Last Post: 03-06-2012, 01:46 PM
  2. '97 GTP, rough idle
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 01:14 AM
  3. 3800 wont idle?
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2008, 03:38 PM
  4. Idle issues.
    By TDCRacing in forum General Tech Discussion
    Last Post: 09-02-2008, 11:43 AM
  5. idle issues.
    By TDCRacing in forum PCM Tuning
    Last Post: 09-01-2008, 02:21 PM
