Thread: It's not the PW motor, it's not the switch.....
Results 1 to 8 of 8
  1. #1 It's not the PW motor, it's not the switch.....
    SE Level Member Red97GPGT's Avatar
    grand rapids, MI
    when I bought the car the window worked fine. About a week and a half ago the window went down just fine but it wouldn't go up. I wanted to replace the motor anyway cause that's what I do so I bit the bullet and installed a new one. Hooked everything up window went down, window did not go up. I figured ok it must be the switch then. So i bought a switch from someone here, he verified it worked so I bought it and got it today. Hooked it up, window went down, window did not go up. I assumed that if the regulator was bad it souldn't go down or up. All the connections seem like they are ok. Anyone have any ideas? Please help me I hate this car!!!!
  2. #2 Re: It's not the PW motor, it's not the switch.....
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    how do you keep getting it back up?
    the only 2 things i can think of are the wiring, and the regulator. you should try taking a voltmeter to the motor connection and see if theres power there when you press the up button, if so, then i would guess the regulator. from my personal experience, and from what ive read, the motor/regulator is a pretty common part to go out on these cars
  3. #3 Re: It's not the PW motor, it's not the switch.....
    grand rapids, MI
    to get the window back up I keep taking the motor off of the regulator and pulling it up. I know for a fact that the motor isn't the problem because it is brand new! Is it possible for the regulator to be bad if the window goes down fine? I haven't touched and of the wiring so I'd imagine that is fine, so then it must be the regulator then?
  4. #4 Re: It's not the PW motor, it's not the switch.....
    Banned - Busted For Scamming
    Feb 2009
    you need to take out the regulator and visually inspect it. It could be possible that the cables for the up side has broken. Also, can you hear the motor running on the up? That would be an indication if its the regulator or not.
    Logan
  5. #5 Re: It's not the PW motor, it's not the switch.....
    Nov 2008
    Fremont Nebraska
    i meant the connection at the door, the connector you plug the motor in to, test for electricity there while pressing the up button.
  6. #6 Re: It's not the PW motor, it's not the switch.....
    grand rapids, MI
    nothing happens when I push the up button at all. no movement or anything.
  7. #7 Re: It's not the PW motor, it's not the switch.....
    Nov 2008
    Fremont Nebraska
    i understand that, i meant test the connector for electricity with a voltmeter. the connector attatched to the door, the one you plug the motor in to........ while pressing the up button
  8. #8 Re: It's not the PW motor, it's not the switch.....
    grand rapids, MI
    i unfortunately dont have a voltmeter. Anyone in mi wanna stop by with one?
  1. bad window switch help (GTP)
    By IndeedSS in forum General Tech Discussion
    Last Post: 07-26-2009, 11:23 PM
  2. Dimmer Switch
    By jack08 in forum Visual/Body Modifications
    Last Post: 03-05-2009, 06:29 PM
  3. TC switch
    By pontiac667 in forum General Tech Discussion
    Last Post: 03-01-2009, 12:31 PM
  4. Relocate HUD switch [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 01-27-2008, 07:03 PM
