Thread: Power Windows Help Needed...
Results 1 to 7 of 7
MHolla Power Windows Help Needed... 04-30-2009, 11:16 AM
Lawngoose Re: Power Windows Help... 04-30-2009, 12:01 PM
Quicklynx Re: Power Windows Help... 04-30-2009, 06:12 PM
cutiger80 Re: Power Windows Help... 05-20-2009, 08:31 PM
mzlilib Re: Power Windows Help... 06-30-2009, 07:22 AM
Quicklynx Re: Power Windows Help... 07-06-2009, 04:37 PM
bnbspop Re: Power Windows Help... 07-11-2009, 08:50 AM
  1. #1 Power Windows Help Needed...
    Apr 2009
    Florida
    Hey Guys,
    So my girlfriend just bought a 2000 GTP last week which has about 90K miles. The owner stated that the front passenger and rear drivers windows did not roll down but that he believed that it was the switch in the drivers door. He said he was told that the controls on all the other doors are wired through the drivers door so if I were to replace that switch should fix everything.
    I purchased a whole new drivers bezel which had the switches, locks, etc. put it in last night and still the same issue. The front drivers and rear passenger windows work fine but the opposite rear drivers and front passengers still do not. The previous owner had said that three of the power window motors had been replaced since he has owned the car so he knew that the motor were not the issue and why he believed it was the switches.
    Anyone have any clues as to what this could be or heard of this issue before? I am hoping is it nothing too complicated that I can fix myself. Any thoughts or ideas would be greatly appreciated. Thanks!
  2. #2 Re: Power Windows Help Needed...
    Outer Space
    Get some new/used regulators ... that is a common issue with our cars.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Power Windows Help Needed...
    Jul 2008
    Germantown, Maryland
    yea im in the process of changing mine as well... drivers side won;t roll up
    prepare to spend about $40 a regulator used and over $100 for each new
  4. #4 Re: Power Windows Help Needed...
    Lexington, SC
    Where do you find these regulators? Online or local parts store or junk yard?
  5. #5 Re: Power Windows Help Needed...
    Columbus Ohio
    How difficult is it to fix a regulator? I am having the same issue my driver side window is stuck down.
  6. #6 Re: Power Windows Help Needed...
    Jul 2008
    Basically pull of the door panel, unhook the regulator, then unhook the window from the brackets as the regulator and brackets are one piece. If the window is up its quite a ***** to unhook. Then put the new mechnism in and let the window drop a little and hook it up to the metal brackets. Just a little advice, make sure u look at the brackets still in the car so you know the exact positioning the metal wires are supposed to be in.
  7. #7 Re: Power Windows Help Needed...
    Helotes, TX
    I have the same exact problem and I have already replaced the regulators/motors. Have you had any success at a solution? Any help would be greatly appreciated.
  1. Repair Your Power Windows Switch[*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 10-19-2013, 01:07 AM
  2. issues with windows
    By GTPGirl in forum General Tech Discussion
    Last Post: 03-27-2009, 08:31 AM
  3. Power Windows
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-12-2008, 08:51 PM
  4. Power Windows
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-08-2008, 03:58 AM
  5. Tinting windows
    By robahr24 in forum Visual/Body Modifications
    Last Post: 02-26-2008, 01:15 PM
