Thread: vac leaks AHH ***updated at top of post read new thoughts ***
Results 1 to 18 of 18
Threaded View
gotboost3 vac leaks AHH ***updated at... 04-29-2009, 02:09 AM
Bio248 Re: vac leaks AHH 04-29-2009, 08:43 AM
gotboost3 Re: vac leaks AHH 04-29-2009, 10:46 AM
Guest Re: vac leaks AHH 04-29-2009, 10:52 AM
gotboost3 Re: vac leaks AHH 04-29-2009, 12:02 PM
Guest Re: vac leaks AHH 04-29-2009, 12:22 PM
gotboost3 Re: vac leaks AHH 04-29-2009, 02:22 PM
2000GTP Re: vac leaks AHH 04-29-2009, 02:31 PM
Guest Re: vac leaks AHH 04-29-2009, 02:48 PM
gotboost3 Re: vac leaks AHH 04-29-2009, 03:14 PM
Guest Re: vac leaks AHH 04-29-2009, 07:16 PM
Bio248 Re: vac leaks AHH 04-29-2009, 03:53 PM
gotboost3 Re: vac leaks AHH ***updated... 04-30-2009, 01:55 PM
Lawngoose Re: vac leaks AHH ***updated... 04-30-2009, 03:11 PM
gotboost3 Re: vac leaks AHH ***updated... 04-30-2009, 03:22 PM
Bio248 Re: vac leaks AHH ***updated... 04-30-2009, 04:14 PM
gotboost3 Re: vac leaks AHH ***updated... 04-30-2009, 04:40 PM
DanGTP Re: vac leaks AHH ***updated... 04-30-2009, 05:51 PM
  1. #1 vac leaks AHH ***updated at top of post read new thoughts ***
    Donating Users
    Plainfield, IL
    ok guys so i thinki found the vac leak.....my trims arre at +16.4 ....but when i spray carb cleaner all around the base of the sc and go check my trims they are at 9.4, and 2-3 mins later they go back to 16.4...now i thought carb cleaner causes a raise in idle and i dont get that....is it possible that the leak is so small that only a very small amount of carb spray makes it in and the carb spray seals the leak momentarily with fluid? im thinking bad sc gasket yeah?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  1. How to Trace Vaccum leaks for P0171 [*]
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2012, 09:52 PM
  2. leaks...
    Last Post: 04-21-2009, 10:20 PM
  3. Common oil leaks and fixes?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2008, 07:56 PM
  4. Coolant leaks
    By golden_c_ninja in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2008, 10:13 PM
  5. Do oil treatment additives actually stop leaks?
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 04-08-2008, 02:17 PM
